Old 02-02-2003, 06:39 AM   #1
Cole Trickle's Avatar
Default 48 versus 64 pitch
I know this may seems like and old question. I know that 48 pitch uses to last a little better and they are a little noisier too. The 64's are known for more efficiency.
But how much more effective are they? Can it actually be felt while driving or can it be measured?
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-02-2003, 10:06 AM   #2
If you measure effectiveness by gear ratio selection, then 64 pitch offers more options. The car will sound quieter and some folks think they are more efficient at laying down power.
I use 48 pitch outdoors because the spurs don't strip as easily. I use 64p on carpet.
I always recommend that newcomers to racing start with 48p because they are easier to mesh and are more durable.
coolrcdad is offline   Reply With Quote
Old 02-02-2003, 12:08 PM   #3
Well, I've been driving for 2-3 years and got a good selection of 48 pitch. If I choose to go to 64, it will be indoor only.
By effecience, I was thinking about less powerloss in the drivetrain. Will I gain an advantage, if I spend the money and go to 64 pitch?
Old 02-02-2003, 12:12 PM   #4
Trips's Avatar
Trader Rating: 16 (100%+)
The actual difference in efficiency is very slight if any. THe real advantage to 64 pitch lies in the finer gear ratio selections available.
T
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-02-2003, 01:21 PM   #5
Super Moderator
Grizzbob's Avatar
Exactly, while there may be a very slight advantage in efficiency for 64 pitch, it's so small I doubt many people could ever notice. The best reason by far to go with them(if you can mesh them properly, it is more difficult than for 48 pitch) is the extra gearing flexibility, going up one tooth in the pinion makes a smaller difference than in 48 pitch, so you can make finer gearing adjustments. And of course the downside is if you're more prone to hitting stuff, you run a higher risk of stripping spurs with 64 pitch, so your driving also needs to be up to par....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 02-02-2003, 10:47 PM   #6
Thanks. I'll stay with my 48's and spend the money somewhere else.
Converting TC5 from 48 Pitch to 64 Pitch??? jdob Rookie Zone 3 06-23-2007 11:10 AM
48 pitch pinions cheap/or trade for 64 pitch pinions Got Xray? Australia For Sale/Trade 2 05-26-2006 11:04 PM
MF 1 versus mf 2 D Mac Electric Off-Road 22 11-06-2005 06:17 AM
27 mHz versus 75 mHz? chachi Nitro On-Road 3 01-25-2004 01:48 AM
BC Versus HH ChrisCrash Racing Forum 0 08-05-2003 12:20 PM
