Old 08-30-2006, 11:30 PM   #1
Default Servo Glitch
I noticed tonight that my steering will twitch at certain speeds. I had just installed a cap on my competition 2 esc and was just checking to make sure it was working. Well at full throttle everything is fine. But I noticed somewhere around 1/4 throttle the steering servo will twitch badly. Can anyone tell me why it would do that? I have a JR xs3 radio, RS310 reciever, and Hitec 965mg servo. Thanks.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 08-31-2006, 01:19 AM   #2
Some possible reasons...
Your antena too close to ESC wires or touching carbon fibre.
Or it could be your crystal damage...Or worst, your radio is damage.
Or your motor is too old and comm out of round and its making a lot of electrical noises at full throttle.
Check these out.
Ben.C is offline   Reply With Quote
Old 08-31-2006, 05:19 AM   #3
Most of those are pretty clear. Motor is a co27 with 4 runs on it. Don't have any crystals. I'll try moving wires away from antena.
Check these out.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 08-31-2006, 05:22 AM   #4
JAY_UK's Avatar
Send a message via MSN to JAY_UK
Are you running Spektrum system?
JAY_UK is offline   Reply With Quote
Old 08-31-2006, 07:15 AM   #5
Make sure you are in normal response mode. It's in the menu where you change the frequency.
trf_racer is offline   Reply With Quote
Old 08-31-2006, 07:33 AM   #6
cbrfreak's Avatar
I just fixed that same trouble with my son's buggy and my truck. We use XS3's also.
Get a new receiver and the glitch will be gone.
cbrfreak is offline   Reply With Quote
Old 08-31-2006, 07:36 AM   #7
Is this the frame rate on the transmitter?
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 08-31-2006, 07:49 AM   #8
Yes, that's it!
Old 08-31-2006, 07:52 AM   #9
Thanks. I'll check it when I get home. Haven't ever looked at it since I guess I assumed it came set for normal. Could be I accidently switched it too.
Yes, that's it!
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 08-31-2006, 12:52 PM   #10
I have a few receivers so I'll try it. Hope it's not it as the receiver is basically new. He was getting glitching at lower throttle only?
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 08-31-2006, 01:04 PM   #11
cbrfreak's Avatar
Both of our cars had the same symptoms. Light throttle was causing the steering to twitch and the motor was kind of glitchy acting too.
I had to get a new receiver for mine and a new speedo for his. Both had the same symptoms you are describing.
Old 08-31-2006, 04:47 PM   #12
yep it's on normal.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 08-31-2006, 07:31 PM   #13
Tek Nickal's Avatar
Default Having the same problem
I'm having the same problem with my JR XS3 also, the servo twitches left to right at certain speeds. Esp. at very very low throttle, and then less when more is applied. My antenna isn't touching graphite, and isn't going over any wires.
Tek Nickal is offline   Reply With Quote
Old 08-31-2006, 07:34 PM   #14
cbrfreak's Avatar
If you have a different speedo to try, do that. If it still glitches then it's your receiver. Trust me, I pulled my hair out for a week tracking the problem down.
Old 08-31-2006, 07:35 PM   #15
Tek Nickal's Avatar
High power servo glitch? Revo-lution Radio and Electronics 1 04-24-2009 07:53 PM
Digital Servo glitch problem ckaspar Radio and Electronics 2 06-05-2008 04:19 PM
JRXR2 Radio 2 receivers JR Z650M Servo Batteries Glitch Buster Tires hardey R/C Items: For Sale/Trade 6 01-15-2007 02:19 PM
Can a servo cause a glitch? Iceracer Electric Off-Road 10 04-04-2006 02:07 PM
