Old 08-31-2006, 07:37 PM   #16
Tek Nickal's Avatar
Originally Posted by cbrfreak
If you have a different speedo to try, do that. If it still glitches then it's your receiver. Trust me, I pulled my hair out for a week tracking the problem down.
This was after I moved my electronics from a different car, and this didn't happen on the car which I had moved it from. (Yokomo CGM to Tamiya MSX)
Tek Nickal is offline   Reply With Quote
Old 08-31-2006, 07:42 PM   #17
cbrfreak's Avatar
I raced my truck on Friday and pulled all the electronics out of it for a good chassis cleaning. Put it all back together and had the problem. SAME CHASSIS!
You can pull your hair out looking for a different cause, or you can try what I suggested. It's up to you.
cbrfreak is offline   Reply With Quote
Old 08-31-2006, 07:46 PM   #18
Tek Nickal's Avatar
I don't have a different ESC to try, and pulling the electronics out after I just put them in seems......like a big pain in the yeah. Also the electronics are clean, I opened up the reciever, dumped all the dirt out, the servo, and the ESC...well I can't really clean that more than the outside of it.
Old 08-31-2006, 08:14 PM   #19
Does it glitch when it is out of the chassis?
trf_racer is offline   Reply With Quote
Old 08-31-2006, 08:20 PM   #20
Tek Nickal's Avatar
I should try that, then if it is the problem maybe a extra layer of servo tape will do the trick.
Old 08-31-2006, 08:23 PM   #21
cbrfreak's Avatar
Ours wouldn't glitch when pulled away from the chassis so I tried extra tape too... For some reason my receiver just became overly sensitive to interference.
Old 09-01-2006, 07:08 AM   #22
Well I've changed almost everything. One thing I noticed is that it is much worse on a full battery. Thought it was mostly gone then put in a fresh pack and it was real bad again. Gonna switch out the servo next. Have changed receiver, esc, and motor already.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 09-01-2006, 02:56 PM   #23
Tek Nickal's Avatar
well, if thats the last thing, and if its still bad, then its probably your car, or maybe try an entirely different thing on the same car.
Old 09-01-2006, 06:29 PM   #24
Well it's not the servo either. Any other ideas? I'm going to take everything out of the car and see what happens.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 09-01-2006, 08:08 PM   #25
So I can leave the motor and esc in the car and pull the servo and receiver off to the side and I get no glitch. Any ideas what I can do now? Obviously I need the receiver and servo in the car. Thanks.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
High power servo glitch? Revo-lution Radio and Electronics 1 04-24-2009 07:53 PM
Digital Servo glitch problem ckaspar Radio and Electronics 2 06-05-2008 04:19 PM
JRXR2 Radio 2 receivers JR Z650M Servo Batteries Glitch Buster Tires hardey R/C Items: For Sale/Trade 6 01-15-2007 02:19 PM
Can a servo cause a glitch? Iceracer Electric Off-Road 10 04-04-2006 02:07 PM
