Old 08-30-2006, 03:19 AM   #1
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
Default controller crystal problem
hey guys,
i have a futaba 2PHK controller and at the moment im running a 75.630 crystal. Although in Australia u cant race with this because its the emergency radio frequency. So i bought some new crystals (29.865) and they dont work...(and yes they are the same) My reciever is a Futaba FP-R122JE. Anyone know why they arent working and how i can fix it....
thanks
surrealmaterial is offline   Reply With Quote
Old 08-30-2006, 04:16 AM   #2
shakzool's Avatar
i`ve read that you cant change between such a big number ?
shakzool is offline   Reply With Quote
Old 08-30-2006, 04:44 AM   #3
shift's Avatar
your receiver is a 75mhz receiver you will have to buy a 29mhz receiver for the crystals to work
shift is offline   Reply With Quote
Old 08-30-2006, 04:53 AM   #4
ahh...crap .....so theres no way of getting it working...
Old 08-30-2006, 04:56 AM   #5
shift's Avatar
nope the only way for it to work is to buy a new receiver
Old 08-30-2006, 04:57 AM   #6
but my friend has the exact same one, and his works....
Old 08-30-2006, 05:06 AM   #7
swap m
Markiempje is offline   Reply With Quote
Old 08-30-2006, 05:07 AM   #8
shift's Avatar
yeah because his receiver will be a 29mhz version of it if you try your 75mhz crystals in his they won't work. do you follow
Old 08-30-2006, 05:14 AM   #9
yeah i do,
a 75mhz transmitter only works with 75.xyz crystals and a 75mhz receiver with a 75.xyz crystal.... if youre having a 75 transmitter you have to use a 75mhz receiver and a 75mhz crystal. just pick another number
if you want to run on 29mhz receiver , you'll have to make sure you also have youre transmitter sending 29mhz signals witch i guess it wont do because its 75mzh?
Old 08-31-2006, 01:45 AM   #10
ok thanks guys....
Is My Crystal Bad? smarking1212 Rookie Zone 3 06-21-2008 08:15 PM
crystal or crystal set wanted cheap fordman86 R/C Items: Wanted to Buy 3 10-18-2006 08:09 PM
crystal SalvadoriRacing Electric On-Road 8 10-04-2004 08:51 PM
Crystal Sodom Singapore R/C Racers 4 02-28-2003 07:42 PM
