Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks.
#2162
Moderator
First:
Don't judge your car's handling by the first run of the day.
Rear wheel drive cars are very sensitive to track conditions.
Most of the times my car tends to be a handfull to drive for the first few runs of the day, untill a clean line is formed on the track.
Second:
If your car still spins out even after say 4 runs, first adjust your driving: roll on the throttle coming out of the corner.
Last:
If this doesn't help take soem steering out of the car.
- Less traction compound on the front tires,
- softer center shock (oil/spring)
- thicker lube in tubes (if you have tubes
- harder front tires and/or softer rears.
Second:
Last:
#2163
Try slightly harder front tire or slightly softer rear tire. I normally experience the same problem as yours if I use traction additive on my rear tire, once the additive runs out. The car is not drivable sometimes.
#2164
remember, these cars put a huge percentage of their power directly to the rear wheels, unlike a 4WD sedan which puts that power more evenly to all four wheels. . . so you can't drive it like a sedan - i.e. you can't just stab the throttle and expect to go straight! In fact, don't ever expect to stab the throttle, at rest, and expect to accelerate straight away. . .
Driving pan car teaches throttle control. . .you really need it. Your car will reward you for it.
Did you say what tires you're running? I don't think you did (or I can't find it) - Azmio has good advice! Personally, I like green or pink rears. . . ymmv so figure out what works for you.
#2166
@Powell racing components
hey doug,
I send you a mail with some changes on the design through another mail adres as my hotmail is acting up.
hey doug,
#2167
PRC/CRC - 235 car
Hi this is my friend driving the PRC/CRC 235 pancar that i have sold before it was finished. Thank god he finished it and he´s using it! It only takes a few laps and then he just destroy the 1/8 and the NT car...i was located down in the pit, and the car is awsome...
+ YouTube Video | |
#2168
Thanks Thomas for posting it!
#2169
Really nice to see him creeping up on the nitro cars and overtaken them in the corner great stuff.
Could you sometime make a pic of the finished car? (without the body)
Would appreciate it.
#2170
#2171
hey thanks for the pics,
Could be i am stuck to the older rc10l2 servo layout but I never saw a servo mount the way you did ( well except the old trinity evo10) . Couldn't you fit the servo the other way around? Or you acchieved something significant with the layout like this? Better ackerman or something else?
Just really curious
How are those intellect lipo's running? Are you using the 5000 or 8000 ones? I am planning to buy some of those as well but didn't read any experience yet.
Just really curious
#2172
Just really curious
Just really curious
There wasnt enough physical space for the servo the other way so i tried a corally old fashioned style layout and i guess it gives a little more steering.
Regarding the batteries i am pleased with them, i usually use them with a 6.5motor on our little smaller hometrack (not on the video), they are 3800mah and did cost me 50USD each from hongkong. When i am on larger tracks my orion lipo´s with 5300mah jumps in
I am curios to build an exact copy of this car but with a mambamax or monster esc and 3s lipo´s to see if could gain som higher top speed. Would be fun to try but it need to be a separate car, this is my racemachine.
#2173
did you use a standard size servo? i know the wheelbase of the original pantoura is 1 cm shorter then a "normal " pancar . 155mm instead of 165 (rc10l2) and i think this version is 155mm as well. So i gues it is between the servo and the battery wich is shorter.
edit: How many cm were you short? I am planning to use a low profile servo, and it needs a clearance of 1.2cm behind the servo posts.
#2174
