Old 09-26-2008, 08:44 AM   #2086
Thomas P's Avatar
Thanks you John for your consideration about the Widepan car. Im no Ace but after 26 yer in this hobby i realy hop i can do this, otherwise il quit.
PRC have started anyway with it
Tp-Parts | ARRMA| Nero 6s BLX | Kraton 6s | Kraton SWB 6s | Talion 6s BLX | Granite 6s | Typhon 6s BLXv2 | Senton 6s
Thomas P is offline   Reply With Quote
Old 09-30-2008, 02:47 PM   #2087
V12
V12's Avatar
My wide Pantoura now had the 2nd race last weekend.
A regional series now added Pro10 to the current touring and 1/12 scale classes. This was the first race of the 2009 series with 5 drivers running the Pro10 class. Rules allow running 200 or 235mm cars, unlimited bodies, batteries up to 6 cell Nimh or up to 2 cell Lipo, unlimited motors but.....8 minutes runtime. For me it was first time running 8 minutes and foams on carpet since..... well very long time.
Because of very little practice time I was using the Pantoura exactly as in the outdoor race, just trying different tires. For power I also went with the same 7.4V Lipo and BL motor as before. From the beginning the Pantoura worked very good just a little slower than the 1/12 scale cars. During qualifying I won all of the 5 rounds and had the fastest lap also. For the Finals Lotus (here from the forum) did choose his faster 235 car instead of the 200mm before. We had a hard but very fair battle through the finals were Lotus had the faster car in leg 2 and 3 but had some problems with duration and motortemperature. I had choosen a very smooth ESC setting for saving runtime and motortemperature but a little slower laptime also. Finally this paid of with winning all 3 legs of the Finals. At the Finals I also could beat the results of the 1/12 class with faster laptime and overall result this time.
V12 is offline   Reply With Quote
Old 09-30-2008, 04:47 PM   #2088
Grenade10's Avatar
Trader Rating: 37 (100%+)
V-12 Glad to hear you did well with the car. My outside set up was a little different for the tires and a little softer on the springs ..... and your there.
Our small track I'm not quite as fast as the 12 scale cars but we are really close. Running the 200mm car for the small lanes.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 10-01-2008, 09:49 PM   #2089
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
V12- good finish with that wide Pantoura. I thought I would repost this picture of the one I tested. Very nice work by Doug Powell at PRC. The front shocks are a home modified addition. These nerf wings are no good as they break and then gouge up the tire. Get flat graphite plate Pantoura Nerf wings or Darkforce Nerfwings. Also note home added RC18T shocks used for side shocks. This is a really nice very strong small lightweight shock.
Johm
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks.-powell-chassis-front-006-resized.jpg
John Stranahan is offline   Reply With Quote
Old 10-02-2008, 10:13 AM   #2090
V12
V12's Avatar
Yes the chassis from Doug is very good. But mine was modified a little and isnīt exactly the same. Overall this car isnīt as aggressive on the steering as some others but allow a very smooth and consistent drive what will be fast in a long run.
The Pantoura also seems to me a very strong car what will prevent a DNF in some hard crashes. From what I have seen some certain 200mm cars are breaking easily at a hard crash. This is especially true when youīre running tracks with wooden barriers but itīs just good we donīt have this very often.
Maybe this is not a problem with slow motors but we always run Lipo and at least a 9.5T BL motor if not in the 4.5-5.5T range.
Of course the original Pantoura may be a little outdated in some areas but itīs quite easy changing this.
On some smaller tracks I could think of a 200mm car also but the more I think I would like testing a ......... someone want selling a 200mm pantoura?
Old 10-02-2008, 11:02 AM   #2091
V12
V12's Avatar
Regarding the RC18T shocks, yes the Factory version isnīt that bad. Iīm using 4 of them on one of my other Pro10 cars, the Hatzenbach.
My wide Pantoura actually was made as sparecar for racing in the wet and I wanted a simplier design for this so opted for the tubes. Of course tubes have to be refilled more often than shocks but I like how theyīre working. Itīs just important using the right ones. I think the old CRC are very good.
Old 10-02-2008, 01:17 PM   #2092
Thomas P's Avatar
since i race 1:18 TEK18X i have 2 pairs new unused FT shocks, but im not sure, i will test with Tubes to.
John, real nice
/Thomas P
Old 10-02-2008, 03:11 PM   #2093
Grenade10's Avatar
The I-Fource is in the same arena as the Pantoura .... So we can get on into your hands for not much more than the price listed on the web site ...LoL..LOL.. www.darksidems.com .... !!!!
Old 10-04-2008, 06:58 AM   #2094
Thomas P's Avatar
Johm
John, may i ask how long those FT turnbucles are for steering ?
/Thomas
Old 10-04-2008, 08:44 AM   #2095
I'll measure mine and post it on this message this evening. 2.40 inch.
John
Old 10-04-2008, 09:27 AM   #2096
Thomas P's Avatar
Thank you John, i appreciate it
Old 10-05-2008, 05:18 AM   #2097
V12
V12's Avatar
Thomas you have mail.
Old 10-06-2008, 08:57 AM   #2098
Thomas P's Avatar
Thank you V12
Old 10-06-2008, 12:14 PM   #2099
V12
V12's Avatar
No problem.
Regarding the turnbuckles I think when using the CRC front end you will need shorter turnbuckles as the steeringarm uses a different angle.
I think the 2.40 may be too long here.
Old 10-10-2008, 09:38 AM   #2100
Thomas P's Avatar
Recived some parts
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 04:31 PM
Xray T2R, 2100 mah 2c LiPo, and Mabuchi power: Tech tips and Tricks gacjr0 Electric On-Road 46 11-18-2007 10:09 AM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips & Tricks Steevo Electric On-Road 54 08-08-2003 10:09 PM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
