Old 08-29-2006, 11:53 AM   #1
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Default Having a quiet car.
Just wondering why some people can can have a quiet car, and others own the same car and it's noisy as all hell.
I've run a TT01, and it's got some noise going on, and another guy has the same type of TT01, box stock, bearings only, and the only noise it puts out is the tyres rubbing across the track when cornering.
Anyone got any advice on running a quiet car?
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 08-29-2006, 11:56 AM   #2
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Most noise comes from bad spur & pinion gears. Also 64 pitch is much quieter than 48 pitch.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 08-29-2006, 11:57 AM   #3
HarshGuy's Avatar
I was wondering the same thing about wives.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-29-2006, 12:11 PM   #4
drsfly's Avatar
Default wives
"I was wondering the same thing about wives"
Now that is funny!!!!
I am sure it has something to do with a bad "mesh"(gear)-- your car-- my wife!
I just couldn't go there about a bad " pinion" fit!!
Everything needs just a little room to breathe. --- pinion and spur that is.
Darrald
drsfly is offline   Reply With Quote
Old 08-29-2006, 12:45 PM   #5
timmay70's Avatar
Darrald
Here I was thinking about ballgag to mouth tolerances...
I think the consensus is correct, worn out pinion/spurs will make nasty noises as will dirt lodged in the plastic spurs or even the cogs of a belt or pully.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 08-29-2006, 01:00 PM   #6
MK_Arbiter's Avatar
I have a wrecked spur and pinion on my ta-05. it runs properly but it sounds kinda funny. lol
MK_Arbiter is offline   Reply With Quote
Old 08-30-2006, 03:35 AM   #7
To get quiet car you need need precision made gears with the correct tooth profile. Thinner gears are usually quieter. 64 pitch are usually quieter than 48. Worn gears are louder. The rest of the drivetrain (gears in driveshaft cars and belts in belted cars) has to be clean and all bearings have to spin freely with no noticeable wear.
You're driving Tamiya, most Tamiyas come with metric gears that are like, but not the same, as 48 pitch. If you're using 48 pitch pinion with metric spur you'll get lot of noise.
Don't be fooled by exotic materials in pinions or spurs. My RRP steel pinions are much quieter than my Tir titanium pinions (both new) and the RRP are almost twice the width.
andsetinn is offline   Reply With Quote
Old 08-30-2006, 04:57 AM   #8
if youre both running the exact same stock gearing and then noise isn't coming from the motor, then ya, its probably the meshing, though with the tt01, the meshing cannot be fine tuned, or not that i know of. it has specific mounting holes. make sure youre both using the proper mounting holes, and also try putting some gear lube on your gears too, and make sure its enough, check with local racers how much is enough. that should reduce the noise.
SSJChar is offline   Reply With Quote
Old 08-30-2006, 05:26 AM   #9
Tornado_Racing's Avatar
PRS (Precision Racing Systems) has the largest variety, the most outstanding quality, and the BEST gear mesh in the business. All of our gears are machined so run-out is almost zero. What does this mean, with a zero runout the pinions and spurs run as perfectly true and straight as perfect can get. Our gears make NO NOISE when used together. The narrow tooth profile reduces friction and weight as well. PRS gears are a bit on the high side but you pay for what you get. Top of the line Racing Gears.
www.prsrc.com
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 08-30-2006, 07:46 AM   #10
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
www.prsrc.com
I use a Precision spur on my JRXS. I have had many people comment that my car is almost silent compared to others...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 08-30-2006, 08:04 AM   #11
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
www.prsrc.com
I totally agree, my only complaint is that the pinions don't fit the T2 all that well.
I had completely bought a 48p and 64p sets of your gears..... But the pinions are too tall to get the proper fit on the T2. When I used them on the RDX it was silent.
FOr the T2 the Xenon ones do the trick, they have two different set screw locations and are shorter.
Hope that gives you all the options you need.
And as for the TT-01 or the other Tamiya low cost kits...The gear mesh is setup by where the screws go into the motor, and isn't very efficent.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-30-2006, 08:12 AM   #12
-Shookie <><
What do you mean "Too tall"? Do you mean too wide? Our pinions are among the shortest available, and our countersunk spurs were re-designed to fit the T2.
Tony Moffre
Old 08-30-2006, 08:37 AM   #13
I am not bashing.....I loved them on my RDX I did buy two complete sets...
Too tall means that where you have the set screw in relation to where the teeth are that distance is too far apart so that the when trying to attach to the motor the teeth will not line up.
If you set the teeth on a table........the height to the set screw is too tall.
That is my only complaint, as they just won't work with my T2 unless I shim the motor outward away from the motor mount and well that messes with center line weight. Using the stock or RW spurs recommended for the T2. That was what I was saying.
I will have to buy a newer redesigned spur, and try it with the pinions again.-Shookie <><
Old 08-30-2006, 08:45 AM   #14
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
CHanging a spur gear in a FK05 Sucks A$$! lol have to take the rear right or the rear left of the car off to get that dam layshsaft out!
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 08-30-2006, 08:50 AM   #15
No problem, and by no means did I take your post as bashing. If we have problems with our products we like to hear about them so improvements can be made.
What do your pinions look like? We have had 2 different designs. Our latest called the "shorty" does not have the lip on the set screw side and the recessed area is much narrower.
Below is a pic of our "shorty" pinions (on the rack) and our older version. Sorry for the blurry pic.
Tony Moffre
It's Bloody Quiet in Here !! Victor Vector Northwest Racers 158 05-24-2014 05:57 AM
The Quiet Pipe Petition OTE_TheMissile Racing Forum 14 01-19-2008 08:51 PM
Whisper Quiet? marzin Singapore R/C Racers 7 09-30-2005 10:46 PM
What Is The Most Quiet Air Compressor You Know? SHOP UFO Painting, Designs, Graphics and Photography 12 10-20-2004 04:00 AM
quiet pipe for break in? tomkelley Onroad Nitro Engine Zone 6 07-27-2004 01:06 AM
