Old 08-28-2006, 12:33 PM   #1
RaceAce701's Avatar
Trader Rating: 86 (99%+)
Default Tire truer Question
Hi i am lookin for a tire truer but i dont want an automatic.
I was looking at the integy ones
http://integy.automated-shops.com/cg...06106401824.0a
http://integy.automated-shops.com/cg...55106433024.a4
has any one had and experience with them and how are they.
As long as it cuts straight and has a size indicator on the cutter like the hudy one has it will b fine for the handfull of tires i will b cutting
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-29-2006, 08:47 AM   #2
RaceAce701's Avatar
Can everyone atleast tell me wat truer they use and the goods and bads about it
Alex "ACE" Kubilus
ACE design works
Old 08-29-2006, 09:06 AM   #3
Trader Rating: 69 (100%+)
i havent used either one (but i do use an integy auto tire truer), and from looking at both truers you posted, i suggest getting the one with the replaceable arbor (the first link) so you can true foams for different types of cars. also, the motor in this truer looks to be a larger, heavier duty type compared to the other one (2nd link). you do have to buy a separate arbor for each type of rim that you will be truing (eg. touring, pan, 1/8, etc.) and that will cost you at least $15-$20 each arbor.
i think one of the truers you posted has a built in hex adapter (the 2nd link) that can be used for touring cars only
why not buy the integy automated truer? if you buy online (tower has discount codes), the discounted price may be pretty close to the manual truers
also, you may find additional tire truer info in this thread (from nitro onroad forum) ...
http://rctech.net/forum/showthread.p...ght=tire+truer
marvi is offline   Reply With Quote
Old 08-29-2006, 09:40 AM   #4
RCSteve93's Avatar
I own the Integy true cut lathe and all I can say is it is awsome. I was even able to bend a piece of heavy duty lexan into a guard so the foam doesnt fly around.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 08-29-2006, 09:40 AM   #5
RaceAce701's Avatar
Thanks ill look into it
Alex "ACE" Kubilus
ACE design works
Old 08-29-2006, 10:12 AM   #6
timmay70's Avatar
I also have the tru-cut, and it works great. I only have only one motor to worry about, and the slides are sufficently protected from the dust. It uses standard arbors from the likes of Hudy, Ofna and ofcourse Integy. The integy arbors run pretty true, too. I found with a weaker power supply the motor does bog a little, but since our shop acquired a 35 - 40 amp 12v power supply, I have just as much power as the Hudy or Ofna.
I did use an Ofna auto truer the other night and love the auto feature. But if it were that or the extra $100 to buy wheels with, I'd take the wheels and deal with turning the tires manually.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Tire Truer Arbor Question ZipZap Electric On-Road 1 05-17-2008 12:22 AM
rookie tire truer question tony montana Nitro On-Road 5 04-26-2008 06:55 AM
Ofna Tire Truer Question genesisG4 Nitro On-Road 2 03-20-2008 08:00 PM
Tire truer question BugFreak Electric On-Road 0 03-26-2006 05:12 AM
Integy Hudy tire truer question... Shrub Electric On-Road 1 10-23-2003 10:59 AM
