Old 09-06-2006, 11:54 AM   #16
mha
Thanks Pat. Do you guess or know that it reverts to linear mode? Does it hold the 5 Amps? From the fact that the other 5 cells take fairly long to reach their cut off and the fan being switched of I would conclude a reduction in discharge current.
Quantum: Can't make sense out this either.
mha is offline   Reply With Quote
Old 09-06-2006, 12:29 PM   #17
XrayFK's Avatar
Trinity cutting corners? No way!
XrayFK is offline   Reply With Quote
Old 09-06-2006, 05:08 PM   #18
Pat Clark's Avatar
I know that it reverts back to liner mode... As far as a reduction in discharge current its a yes and no answer... After the first cell is done with the pulse mode it reverst to liner 5 amp mode.. So after the pulse 30 amps mode there is a reduction to 5 amp, but no further.. The reason it takes so long for the rest of the cells to reach there cut off is because, when you are in pulse mode you pulse the pack as a whole.. The unit just reads the voltage of each cell as it comes down.. Once the liner mode kicks in you may still some charge left in the other cells, but that means you no longer have a "matched" pack as far as runtime.. If the unit were to keep discharging in pulse it would bring the first cell well below the cut off to allow the others to catch up.. hope this makes sense..
Associated, Reedy, Tekin, Tq Wire, Protoform, Veytrec Design Lab
Pat Clark is offline   Reply With Quote
Old 09-06-2006, 06:27 PM   #19
Trader Rating: 198 (100%+)
OK so the pulse is not a per cell discharge. The unit only measures the rest of the cells to figure avg. volts and run time? So this unit is very different than the MM at a pulse discharge stand point.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 09-06-2006, 06:47 PM   #20
Pat Clark's Avatar
Im not sure if i understand your post... It pulse discharges all the cells...
Old 09-06-2006, 07:40 PM   #21
What I am saying is that the DPD does not pulse discharge each cell on its own like the MM unit does. Yes the DPD pulse discharges, but as a pack only as you have stated.
www.donatelife.net
Old 09-06-2006, 08:24 PM   #22
Pat Clark's Avatar
Are you sure about that this is from the Much More site:
The CTX-D is linear or pulse type discharger and can discharge 1, 3, 4, 6cells or 3, 4, 6cell packs.
Notice how you cant do 2 or 5 cells
Old 09-06-2006, 08:50 PM   #23
Nexus Racing's Avatar
That is referring only to the number of posts on the original MuchMore CTX-D. While it only had 8 discharge posts, it discharged each cell individually by using the battery bars to complete the connection for each cell. The original CTX-D could not discharge 2 or 5 unsoldered cells. From CTX-D thread:
cells 1-6, posts A-H
A1B
*2*
C3D
E4F
*5*
G6H
Post A and B discharges cell 1
Post A and D discharges cell 2
Post C and D discharges cell 3
and so on.....
Now, the CTX-D2's have 12 posts for the ability to discharge/match 1, 2, 3, 4, 5, or 6 unsoldered cells, as well as individual cells within assembled packs, etc.
The CTX-D's have 0.5sec pulses with 2.5sec delays in between...so every 6 seconds of discharge time represents 1 second of actual run time.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 09-06-2006, 09:02 PM   #24
Jochim_18's Avatar
I know that CTX-D2 is the best discharger out there right now but I just don't want to pay an arm and a leg for a discharger......
Old 09-06-2006, 09:42 PM   #25
quantum's Avatar
I know that it reverts back to liner mode... As far as a reduction in discharge current its a yes and no answer... After the first cell is done with the pulse mode it reverst to liner 5 amp mode.. So after the pulse 30 amps mode there is a reduction to 5 amp, but no further.. The reason it takes so long for the rest of the cells to reach there cut off is because, when you are in pulse mode you pulse the pack as a whole.. .
waaaiiiittttaaa minuutttee here.... it discharges the pack as a whole?!? are you sure? if that is true then its really just a dynapulse discharger!
what people are asking here is if each cell is individually discharged. if not, then it cannot be compared to the muchmore ctx-d/2. i gots to think that there might be a understanding here about how this device works, what would be the point of having individual cell contacts in a tray format? only to read voltage/IR of each cell but not discharge individually?
then again, i guess you get what you pay for and maybe this is a glorified dynapulse. i tend not to think so.... can someone confirm either way? a purchase decision is on the line here!
quantum is offline   Reply With Quote
Old 09-06-2006, 10:07 PM   #26
I have been trying to get opperating info on this thing since it was announced months ago. Not one Trinity rep could give me an answer to the length of time it would take to discharge a pack in pulse mod after you run it. Since it is advertised as having Dyna pulse discharging. Now we find out it only does a pulse discharge on the pack as a whole and not each cell individually. It does seem to just read volts and runtime. If this is the case then the price of the unit should be lower. It is a Dyna pulse with a 5 amp tray. I do like the way it holds the cells.
www.donatelife.net
Old 09-06-2006, 11:29 PM   #27
XrayFK's Avatar
That sucks, I thought it pulsed discharge each cell individually.
Old 09-07-2006, 11:00 PM   #28
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
Pat Clark - Do you work for trinity? Just wondering where you get your info.
RoachRacing is offline   Reply With Quote
Old 09-07-2006, 11:06 PM   #29
Super Moderator
Trader Rating: 17 (100%+)
Not sure if Pat actually works for Trinity but he is one of their top local drivers. Pat is definitely in the loop and wouldn't give out false info.
Tekno|JConcepts|TeamTrinity|BOOMrc
Bob Barry is online now   Reply With Quote
Old 09-07-2006, 11:20 PM   #30
Bob - Just asking because the info he is providing is not the same as what has been commonly accepted from trinity. As a hobby shop owner (and DPD owner) I would like to know exactly how the tray works. I have some on the shelf in my store and dont want to give out false info about them.
Corey
Trinity D-90 discharge/equalizing tray wallstreet R/C Items: For Sale/Trade 3 01-23-2007 08:51 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
Lightning battery discharge and equalizing system frank p R/C Items: For Sale/Trade 0 09-11-2006 06:28 PM
TeamWave Lightning Equalizer BringItOn Australia For Sale/Trade 1 08-16-2006 03:26 PM
teamwave lightning discharger flysti Australia For Sale/Trade 5 03-28-2006 05:47 AM
