ESC's and motor choices
Hi im looking at upgrading my tt01 from its 19x2 fireball motor and mtroniks tempo15 esc to somthing a little nippyer.
the ESC and motor will be going into my little brothers car which is why i want both and not just a ne motor!!
im after fairly cheap prices, id like a no limit esc if possible like the mtroniks viper.
As for the motor, the car will be used on a playground and in a large room at my dads work so somthing with a fair bit of power.
also if you could give me any tips on motor and gear ratio, at the mo i use a 19t pinion with my 19x2 motor and its fairly nippy. I do have a 22t pinion and speed tuned gears (which i havent installed) so any advice would be appreciated, links etc and maybe combo deals avalible like esc and moter
cheers
cheers
yer tht does seem the best option but thts a lot of money
id sugest the mamba max system. running on 6 cells with the 5700 kv motor you will be plenty happy. and if youre not get the 7700 kv motor.
Matt
Matt
