Old 08-27-2006, 08:35 AM   #1
offroader's Avatar
Trader Rating: 15 (100%+)
Default Cleaning bearings
hi all,
I wanted to clean some bearings. Has anyone got experiecne with the RPM bearing blaster tool? Does it work if I am too lazy to pull out the shielding (rubber, metal or teflon...I have all these beraings to clean). Any one got a quick and esy way to clean bearings other than the RPM tool?
Any help will be much appreciated
Cheer , Jademond
offroader is offline   Reply With Quote
Old 08-27-2006, 08:36 AM   #2
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
We use the below link to clean bearings etc.
http://www.axiommotors.com/indi-sparkle-p-171.html
dgullickson is offline   Reply With Quote
Old 08-27-2006, 09:04 AM   #3
Send a message via ICQ to rcnewb2004
I have used the RPM bearing cleaning tool. it is very effective. However, u will waste a lot of motor spray on it... i would give its cleaning ability a 80%, but it saves a lot of time!!!! My ultrasonic cleaner, I give it 100% cleaning ability... but it is not time efficent.
rcnewb2004 is offline   Reply With Quote
Old 08-27-2006, 10:17 AM   #4
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Just dump the bearings in a Zip-lock bag and spray in some motor cleaner. Then close the bag and shake out! This method is just as effective as the INDI Sparkle which i've used too.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 08-27-2006, 10:39 AM   #5
ah men! thats exactly what i do. get an empty 20 oz bottle. put about 2 inches of whatever solvent you use and drop your bearings on. start shaking! when youre done lift the seals and put a little oil on the balls. youre done and you didnt have to spend hardly any money.
Matt
mat3833 is offline   Reply With Quote
Old 08-27-2006, 05:53 PM   #6
offroader's Avatar
Matt
Thanks mate. what solvent is effective in this machine? Also, do I need to take the teflon seals off first?? I am just too lazy s
Old 08-27-2006, 05:55 PM   #7
offroader's Avatar
have you tried without taking the seals off? how effective is this if I dont take the seals off?
Old 08-27-2006, 05:56 PM   #8
offroader's Avatar
cool thanks.
Is it advisable to keep your nuts away from the ultra sonic cleaner when its active?
Old 08-27-2006, 05:57 PM   #9
We use Motor Cleaner or Acetone depending on what we are cleaning.
Old 08-27-2006, 06:17 PM   #10
offroader's Avatar
woulndt motor cleaner evaporate?
Old 08-27-2006, 06:35 PM   #11
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
i use motor cleaner. or wd-40 which i prefer, but if you use wd-40 i'd put a good couple drops of bearing oil in it.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 08-27-2006, 08:36 PM   #12
akuhon's Avatar
I use this to clean up my bearing :
But if it's too small .... try this (mostly for GP off road bearing) ..
For cleaning solvent, I use any motor cleaner on hardware store (cyclo, etc..)
All bearing seal must be take of to get best result...
Rgds,
akuhon is offline   Reply With Quote
Old 08-28-2006, 02:03 AM   #13
H I
H I's Avatar
Trader Rating: 18 (100%+)
dgullickson, would I be able to get that from Feral batteries in Australia?
H I is offline   Reply With Quote
Old 08-28-2006, 04:15 AM   #14
Works fine without taking the seals off if the bearings aren't packed with dirt. this is with metal shields which is the only ones i use.
Old 08-28-2006, 07:29 AM   #15
Ya you can contact him and have him add it to his order, which is going out by the end of the Week,.
Cleaning Bearings ~AR~ Gizmo Electric On-Road 12 06-13-2007 07:28 AM
Car cleaning and bearings. simon_allen Electric On-Road 6 03-07-2007 08:29 AM
Car Cleaning, Bearings? Fervidsea Electric On-Road 11 02-08-2006 04:43 PM
cleaning bearings pro4racer Electric On-Road 8 07-17-2005 10:45 AM
Cleaning Bearings mtc3od Electric On-Road 12 11-18-2004 10:00 AM
