Old 09-01-2006, 06:45 PM   #76
Jochim_18's Avatar
whooohhhh... I got my peltier chip today and I'm putting mine together right now. I just need a clamp. Right now I'm testing it I have it upside down I just put the 3racing heatsink on top with a motor clamp on it. So far so good I only have it on for couple of minutes. I'll live it on for a while let see what will happen. To bad I don't have a temp gun........
The peltier chip I got only pulls about 3.5 amps.....
Jochim_18 is online now   Reply With Quote
Old 09-01-2006, 07:29 PM   #77
peded's Avatar
So Will computer CPU Fan work for this application?
Like these?
http://www.radioshack.com/product/in...ductId=2102821
http://www.radioshack.com/product/in...ductId=2102820
Than if so, Then I thought I could maybe bend a copper sheet over the motor to make a clamp of some sort.
http://www.radioshack.com/product/in...ductId=2102495
And for the Thermal stuff, could i use this?
http://www.radioshack.com/product/in...ductId=2216880
http://www.radioshack.com/product/in...ductId=2216879
THanks
peded is offline   Reply With Quote
Old 09-01-2006, 07:31 PM   #78
Jochim_18's Avatar
Well guys it did what it suppose to do. But I guess I'm going with the 2 peltier chip on the next one I'm going to built. This one will do the trick for now it chilled the motor really good I left the motor for about 15 minutes. Now I just need to go get some copper clamp probably it will work a lot better.
Old 09-01-2006, 07:36 PM   #79
Jochim_18's Avatar
The heat sink from radioshacks sucks and they are too small. Go to some local computer store they got some better heatsink. and those copper sheet your talking you can't really bent those they have thin layer of plastic right on the middle you will break it, I know this co'z I've since those just today at radioshacks.
Old 09-02-2006, 11:36 AM   #80
hpipro321's Avatar
man i never thought it would be this hard to find one of those peltier chips... i went to fryes and asked for one and they thought i was crazy and didnt know what the h*ll i was taking about . so i ended up ordering a 350 watt monster that is capable of icing over in 30 seconds
heres some piks of it
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 09-02-2006, 11:51 AM   #81
wherre did you end up ordering it from??? i'm in the same boat, i can't really find exactly what you need.
norcal tom is offline   Reply With Quote
Old 09-02-2006, 12:04 PM   #82
Jochim_18's Avatar
I'm thinking of getting one of those but it's hard to find a heat sink that will accomodate all the heat it will generate. I've seen one of those on ebay.
I found a clamp from integy here's the link:
Integy clamp
Old 09-02-2006, 12:08 PM   #83
hpipro321's Avatar
Integy clamp
well, get this you can only use this sucker for about 3 min or it will frezze ur whole car
im using a 120 mm fan to suck all the heat up
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
Old 09-02-2006, 12:09 PM   #84
hpipro321's Avatar
sorry for double post but it doesent generate that much heat if your worried about that just use a second peltier to cool the monsters hot side
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
Old 09-02-2006, 02:10 PM   #85
Jochim_18's Avatar
How can you make a peltier work more efficient?
Old 09-02-2006, 02:23 PM   #86
jakster's Avatar
move to a colder climate! lol just kidding! i hear they work great at the poles, nort or south your choice!
just a little r/c humor!
jakster is offline   Reply With Quote
Old 09-02-2006, 03:36 PM   #87
hpipro321's Avatar
water cooling
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
Old 09-03-2006, 01:46 PM   #88
XrayFK's Avatar
Originally Posted by hpipro321
water cooling
Phase cooling > water cooling.
XrayFK is offline   Reply With Quote
Old 09-03-2006, 02:07 PM   #89
MK_Arbiter's Avatar
Use it in the freezer.
MK_Arbiter is offline   Reply With Quote
Old 09-03-2006, 04:41 PM   #90
cyber3d's Avatar
You know, it would help if you had a motor case (can) machined from aluminum. It would be best to have a flat block designed as the top surface. This way you could apply the freeze to the block and that will hold the cold longer. Hmmm, may be I should start making custom aluminum motor cases!
I could make a bunch of these:
cyber3d is offline   Reply With Quote
RC motor cooler/freezer aka The Frankencooler that I make martymiller R/C Items: For Sale/Trade 21 11-29-2011 03:55 PM
*** Crazy Motor Freezer ( Motor Cooler ) *** CrazyRonny R/C Items: For Sale/Trade 145 01-26-2008 07:31 PM
MuchMore Motor Cooler + Orion Motor Performance Monitor mugengreg Australia For Sale/Trade 11 01-05-2008 09:56 PM
WTB Motor Cooler woozer71 Australia Wanted to Buy 1 10-03-2006 08:13 PM
Much More Motor Cooler JohnMatrix R/C Items: For Sale/Trade 2 06-16-2006 02:27 AM
