Old 08-28-2006, 10:45 PM   #46
porsche928gs's Avatar
peltiers, you can buy on ebay for about $10 to $15 for a 40mm and a good fan and heatsink about $40 the clamp maybe $10
porsche928gs is offline   Reply With Quote
Old 08-28-2006, 10:45 PM   #47
Jimmy Morris's Avatar
Inside mine got to like 15 degrees F, and outside like 27 if i remember correctly.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 08-28-2006, 10:48 PM   #48
could you photograph the gluing procedure so it will be more clear? maybe a drawing of what areas to put the thermal paste and where to put the adhesive
Old 08-28-2006, 10:50 PM   #49
I just measure mine and is 70 room temperature and it went down to 56
Old 08-28-2006, 10:55 PM   #50
I guess the thermal epoxy alone, doesn't last long as using both the epoxy and paste.
Old 08-28-2006, 11:01 PM   #51
rocketron's Avatar
Trader Rating: 16 (100%+)
you forgot to mention the thermal paste $6 and thermal epoxy $12-$14 and the clamp you used appears to be an old much more piece which would be hard to purchase for $10 and to make a proper copper base and clamp is costly much more than $10 if you are buying materials of the thickness needed. imho the copper base and clamp is the KEY part.
i've made several of these (even water cooled) and honestly would NEVER make another one for the following reason.
i strongly suggest to everyone to simply purchase one of CRAZY RONNY's coolers available in another thread in the for sale forum.
His are $99 shipped until end of august i believe * to save $10-$15 dollars it is just not worth it. especially if you live in an area that gets very hot.
crazy ronny's will work in high heat conditions very nicely.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 08-28-2006, 11:06 PM   #52
I used a copper clamp on one of mine and a aluminum on another. The copper would stay cooler longer but it took a lot longer to cool than the aluminum one. Yes I forgot to mention the price of the paste and epoxy.
Old 08-29-2006, 12:28 PM   #53
hpipro321's Avatar
Thanks for all of the input guys
now its just where to find copper that is really thick
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 08-29-2006, 01:07 PM   #54
gee-dub's Avatar
a few thoughts. there are numerous types of peltiers (sealed, non-sealed, different amp ratings, different recovery, efficiency, etc). it's more than just getting one of the commonly used 40x40mm chips. as far as the clamps go, copper is good for the cold side as it conducts the cold better. aluminum is good for the hot side as it dissapates heat well. the hardest part to get right is the clamp itself. i took a trinity motor cooler and chopped one in half (2 dremel grinding blades later). it works well, but... given the hastle, cost, and fact that i now have one that works better, i probably wouldn't bother doing it again.
i got mine from p and c racing (http://www.pandcracing.com). beyond the fact i can frost my motor can/endbell, they got the clamp part 'right'. i do find that removing motor stickers also makes a noticeable difference.
gee-dub is offline   Reply With Quote
Old 08-29-2006, 05:32 PM   #55
That thing looks awsome.
Old 08-29-2006, 05:39 PM   #56
hpipro321's Avatar
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
Old 08-29-2006, 06:25 PM   #57
Getting frosty does not mean that the cooler is Kicking butt. It just means that it has reached Dew Point. Temp guns only measure surface temp. Try wiping the ice off, then gun it.
porsche928gs- Who is the guy in your avitar? He looks Larry Ruby, but the pic is too small for me to be sure.
gezer2u is offline   Reply With Quote
Old 08-29-2006, 07:31 PM   #58
Jochim_18's Avatar
3 Racing clamp will work well. Only Cost $5 bucks on ebay. Just take off the fun. The top surface is flat no modification needed.
Old 08-29-2006, 11:20 PM   #59
XrayFK's Avatar
The 3Racing heatsinks I have seen suck big time, no offense.
XrayFK is offline   Reply With Quote
Old 08-30-2006, 10:28 AM   #60
hpipro321's Avatar
it would work if it was a complete alluminum peice
but can any one tell me how i would make a copper clamp and where to get thick copper to do it?
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
RC motor cooler/freezer aka The Frankencooler that I make martymiller R/C Items: For Sale/Trade 21 11-29-2011 03:55 PM
*** Crazy Motor Freezer ( Motor Cooler ) *** CrazyRonny R/C Items: For Sale/Trade 145 01-26-2008 07:31 PM
MuchMore Motor Cooler + Orion Motor Performance Monitor mugengreg Australia For Sale/Trade 11 01-05-2008 09:56 PM
WTB Motor Cooler woozer71 Australia Wanted to Buy 1 10-03-2006 08:13 PM
Much More Motor Cooler JohnMatrix R/C Items: For Sale/Trade 2 06-16-2006 02:27 AM
