Old 08-24-2006, 04:23 PM   #1
Tek Nickal's Avatar
Exclamation Getting bad cut from lathe
I was cutting a comm this morning (luckily an old one) and once it was done (no deep spots), the finish looked really bad, and it had all sorts of ridges where the cutting bit had been. I think the pictures better describes what I'm talking about.
Tek Nickal is offline   Reply With Quote
Old 08-24-2006, 04:34 PM   #2
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
It looks like your bit is either dull, to low or your way shim screws are too loose for the cradle movement.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-24-2006, 04:38 PM   #3
Tek Nickal's Avatar
I shim the comm so it barely moves, and when it cut, the comm doesn't move. I have the bit shimmed so its in the middle of the comm.
Old 08-24-2006, 04:40 PM   #4
Trader Rating: 18 (100%+)
Lube the cross slide. It is binding up a little. I use a smidge (very small amount) of AE black grease on the teflon slides.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 08-24-2006, 04:43 PM   #5
Team EAM
Yes...this was the item I forgot. The cross slide (part that moves the bit across the comm) must be free and smooth....but it cant twist any on the base of the lathe.
EA
Contact Us
Old 08-24-2006, 04:48 PM   #6
Tek Nickal's Avatar
Thanks, that helped a lot. Now, the comm is smooth but, its not as shiny as it was before. I think its time for a new bit...does anyone know which carbide bit fits the integy auto lathe? Also, where can I get it pretty cheap?
Old 08-24-2006, 04:50 PM   #7
COLEKO's Avatar
Send a message via AIM to COLEKO
Check the speed of your cutting and lathe motor.
The Flying Hawaiian
Team TAOB 2004
COLEKO is offline   Reply With Quote
Old 08-24-2006, 04:53 PM   #8
EddieO's Avatar
R/C Tech Charter Subscriber
Don't buy into the needs to be shiny or look like a mirror.....a smooth ROUND (the KEY) cut with a appearance like the bottom of a CD is what you are after.....int he end though, as long as it has no burrs or jagged edges....and is ROUND, you will be fine.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 08-24-2006, 06:01 PM   #9
drew85's Avatar
Is there anyway to tell if its not cutting round? I was thinkg just go in a bit and make a pass without cutting but moving in a bit at a time intill it hits a high spot..just wanted to see if there was a standered way of doing it.
drew85 is offline   Reply With Quote
Old 08-24-2006, 06:31 PM   #10
Tek Nickal's Avatar
Use a caliper and check the entire comm to see if its the same diameter throughout.
Old 08-24-2006, 06:43 PM   #11
drew85's Avatar
But the arms on the caliper would have to be thin enough to notice the change, I think it would have to be really bad to see it on a set of those. unless it was super thin.
Old 08-24-2006, 07:54 PM   #12
James35's Avatar
Tek Nickal,
Big Jim has been the authority on brushed motors, but even I was a little skeptical with I read Big Jim's post saying that even new carbide bits need to be sharpened!
So I followed his advice, paid $25 for a diamond hand file (220 grit) and learned how to sharpen the carbide bits. Here is how:
http://www.rccars.com/forums/attachment.php?postid=6980
Well, I used an 8X power eye magnifying glass to see what I was doing, and I got pretty good at it. Man what a difference! After sharpening the bit, the cuts look like a copper mirror. It's so easy and fast to sharpen the bits, that I do it ever as soon as 5-8 passes!
After I become proficient at it, I started putting brand new carbide bits up against my hand sharpened bits, and wouldn't you know it, Big Jim was right. The new bits definately have room for improvement and the powerful eye magnifying glass will makes it apparent.
James35 is offline   Reply With Quote
Old 08-24-2006, 08:17 PM   #13
protc3's Avatar
it is very difficult to check for round.you need to either use a dial indicator and spin the arm on the lathe slowly or use a 3 point or anvil micrometer.you need to touch at least 3 points to check for roundness accurately
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-24-2006, 08:30 PM   #14
geeunit1014's Avatar
easy way is to coat the comm with a sharpie before you cut it. once all the sharpie is gone, the comm is round
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 08-24-2006, 08:33 PM   #15
PitCrew's Avatar
What jason says is very true.
Alot of time, not so much with turning (lathe work) but grinding, especially centerless grinding you can end up with a part that is not round, but if you measure with calipers or two point measuring like a standard micrometer, you can NEVER tell it isn't round. The part ends up like a rounded triangle, and every place you measure with two contact points is the same distance across.
PitCrew is offline   Reply With Quote
XXIP Comm Lathe and Orion Quick set lathe vino1 R/C Items: For Sale/Trade 2 01-25-2008 04:35 AM
Trinity Tru Lathe Motor Comm Cutter Lathe maximum R/C Items: For Sale/Trade 4 05-14-2007 04:56 PM
XIPP Super Lathe 3 / (pics) comm lathe diamond bit evostyle R/C Items: For Sale/Trade 8 12-01-2006 12:53 PM
Motor Lathe (Integy Xipp X-Mod Super Lathe) Geppetto R/C Items: For Sale/Trade 15 01-27-2006 05:10 PM
Tire Lathe, Motor Dyno, Comm Lathe For Sale 17Mark71 R/C Items: For Sale/Trade 8 06-05-2005 01:07 PM
