motor question
Old 08-22-2006, 04:59 PM
Racingfreak6's Avatar
Default motor question
I have a integy evo30 19t motor and the LED stopped working.The chip on top came loose in a crash and poped out.So i put it back in and ran it on my ice and seemed to be fine.I am wondering if it is ok to put in my car or is it toast?
Racingfreak6 is offline
Old 08-22-2006, 05:14 PM
I think if the l.e.d. lit up again after you soldered it back on it should be fine.
jeffb is offline
R.Dalnogare's Avatar
i belive that chip is the capacitor, it should run fine, you may want to solder some on there, but it should be fine.
R.Dalnogare is offline
Old 08-22-2006, 05:17 PM
I forgot to add the LED didnt come back on.
Old 08-22-2006, 05:26 PM
dgullickson's Avatar
Trader Rating: 45 (96%+)
Easy fix - There are 4 tabs on the top which connect to the circuit board, Solder those to where it makes contact and it should work again.
dgullickson is offline
Old 08-22-2006, 06:53 PM
I soldered the tabs on and it spun for a second then shot up to a 12-13 amp draw then my ice charger said the motor was disconnected.Any idea why? or is it just maybe my ice charger cant handle it?I even took the motor apart and put it back togeather.
Old 08-22-2006, 08:10 PM
Ryan,
Those motors are notorious for the endbells shorting out. I had one that shorted and Timmmayyyyy was able to fix it real quick like with a dremel. As far as the cap board, just solder some external caps on the tab and endbell and you'll be fine. However, you may want to use a desoldering tool and remove all of the solder that you put on there. That might be the source of your short. Have Stamper check it out and he can get it going for ya again I'm sure. The motor's not toast, you just have to take care of that short and put some external caps on there.
I'll probably be leaving a present for you up at CEFX on thursday or friday. I'll let ya know.
Talk to ya later junior.
Tony
RcCzarOfOld is offline
The ICE cannot run the motor at more than 10 amps for extended periods so it shut down that's all.
If you set the motor run voltage at 1 volt that might let it run. Give that a try.
jeffb is offline
