Old 01-29-2003, 10:07 PM   #1
EDWARD2003's Avatar
Default Looking for AXIS 2 Setups
Hey guys looking for some carpet set-ups for the Axis 2.
Also give us some insight on what modifications you have done onto your Axis 2 to perform better?
Thinking about making a 3mm Graphite thick chassis for the Axis 2.
Tell me what you like about the Axis 2 and how it compares to the New Mission which i bought but sold because it wasnt up to par.
Thanks Edward Pickering
EDWARD2003 is offline   Reply With Quote
Old 01-30-2003, 12:10 AM   #2
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
hey dude. yeah, even the schuie thread doesn't have much info for the axis series. it is one of the best threads on here though. my friend runs an a2 and he talked to paul wynn when we were all practicing for the indoor champs. paul gave him a setup that really works well for our carpet scene. i'll tell you what i know.
- first and formost, run a rigid top plate. the axis one or a 99 pro one will fit atop the existing and tie in. rarely does a flexible machine work on carpet. and the a2 is king of flex.
- with this in mind, do get the stiffer chassis as well if it's in your budget.
- umm here's what i remember for the setup from pw
- front
40 lb spring
70 wt
2 hole
using 99 mounting position (all the way in)
droop 1-2mm
std roll center
no sways
inline kingpin position (be careful and make sure turnbuckle is 2/3 in arm and 1/3 in ballend)
castor in middle position
camber set for even wear (1-1.5)
- rear
35 lb spring
70 wt
2 hole
leaned in as well
droop 2-4mm
std roll center
no antisquat
no sways
camber 2 - 3 for even wear.
whoops forgot to mention that this was with foams. ugghh. big difference. hope it's applicable.
for more questions or setup advice pm paul here or just call them at schuie usa. they are the coolest and nicest dudes around. talk to adrian or paul.
hope this helps
later,
chris.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-30-2003, 05:45 PM   #3
EDWARD2003's Avatar
Default Thanks!
Hey anyone else with any good set-ups with rubber tires on carpet
Old 01-30-2003, 06:58 PM   #4
seaball's Avatar
arghh. rubber!
Old 01-31-2003, 01:36 PM   #5
ottoman's Avatar
If you really want to find out, post your question in the Schumacher thread... Paul answers questions there along with other long time schumacher guys.
ottoman is offline   Reply With Quote
what to ask for a my axis 2 ? papadocks Electric On-Road 4 03-27-2005 09:48 PM
how much is too much 4 a axis 2 papadocks R/C Items: For Sale/Trade 0 03-27-2005 06:46 PM
Axis 2 Art Jensen R/C Items: For Sale/Trade 0 07-14-2003 05:29 PM
Axis II flaunder Electric On-Road 5 02-26-2002 05:59 PM
FS Axis 2 & Axis Touring Sedans Richard Abbott R/C Items: For Sale/Trade 3 01-09-2002 08:04 AM
