Fastrax Motor Cooler (Like MM)
Fastrax Super Cooling System http://www.cmldistribution.co.uk/pro...ST417/main.jpg This is a motor inter-cooling system which enables the user to cool the motor down to near Sub-C temperature prior to use. This process then delays any heating up of the motor during a race, keeping the motor close to maximum performance and efficiency throught a 5 minute run. Improved run time Longer life for com and brush, Retains magnet power normally lost by heat. Features 12v Cooling Fan Heatsink Electric Thermo Element Motor Clamp Crocodile Clip Lead Specification Size - 52 x 70 x 75mm Approx. Weight - 190g Motor Clamp Size - 540 Amp Draw - 3.0-4.0 Amp Input - Minimum DC 9v/12v Max Part # Description Price (RRP) FAST417B Super Cooling System - Blue £39.99 FAST417P Super Cooling System - Purple £39.99 Source: CML Distribution http://www.cmldistribution.co.uk/pro...subMenu=CR-ELC Anyway, Does anyone else this theres a factory in HK or China doing these (unbranded) even cheaper? |
I hope it cools better than my Much More did... I was very unhappy with mine... definitely not worth the price I paid
the problem with tiers is that they use only one 30mm peltier. in addition they do not use any thermal grease between the clamp and the peltier to more effectively transfer the cold. bigger heatsink and two peltiers will always do better, especially in hot air temps which is really the reason you're using one of the coolers anyway. Crazy Ronny, myself and a few others out there have been making what we think are much more effective units for a while. However, the muchmore unit can be more effective if you take it apart and apply some thermal grease on the contact surfaces for the pelties. Make sure it goes back together nice and tight to avoid airgap. |
I did that and it still wasnt what I expected. I think thats the main problem is that people expect alot more.
http://rctech.net/forum/showthread.p...91#post2588491 |
Can you add another peltier to the mm unit?
Originally Posted by killingtime
I'd like to know the same thing! Sounds like the perfect oppourtunity for someone (nordheim ;) ) to write a tutorial!!
Thanks, I'll check it out now.
