Servo works but not motor? >
Old 08-17-2006, 03:42 AM
Default Servo works but not motor?
well i just soldered on my motor last night and i woke up this morning to test my str4 pro and only the servo works, i am useing a orian core modifid 9x2 motor and a novak duslly pics are attached of how i soldered the motor
andrewtexas123 is offline
Old 08-17-2006, 04:16 AM
Ian S's Avatar
Well its going to go backwards for a start unless you have a blue positive and red negative wire from your speedo for some bizare reason. Is the motor new? If not check the brushes, if it needs skimming etc, it could just be a sticky brush. Does the car roll when you push it? If not it could be something in the drivetrain or the motor.
Ian S is offline
Old 08-17-2006, 04:46 AM
is is nothing to do with the drive train or brushes just put brushes in... is it soldered correct?
Old 08-17-2006, 05:48 AM
Ian S's Avatar
No the positive and negative are the wrong way round, brushes look to be soldered ok. Did you skim/cut on the comm before you put new brushes in?
Ian S is offline
Old 08-17-2006, 06:23 AM
ok so i need to switch the to wires arounnd sould that fix the prob?
Old 08-17-2006, 07:17 AM
BringItOn's Avatar
that would help.... to put wires right way. blue to the -ve and red to +ve.
also maybe just flick your brushes, they may be hanging.
BringItOn is offline
Old 08-17-2006, 07:36 AM
TRF415boy's Avatar
No it won't make a difference, even if mounted backwards the motor should run. Besides, you only need to turn the can 180 to make it turn the correct way if the wires are soldered the wrong way around.
If you've recently cut the comm, Check that there is no copper dust in the segments between the comm's poles. Also make sure your endbell's 0 matches the can's 0 point...
TRF415boy is offline
Old 08-17-2006, 08:36 AM
tc3team's Avatar
Its a slim chance I know,but maybe its a dry joint on the soldering? looks like the wires might need tinning a little more.
tc3team is offline
Old 08-17-2006, 08:42 AM
pheyhoe's Avatar
If its making a noise like a high pitched noise then the motor has something physically stopping it from moving. Take the motor out the car and see if you can spin the main motor shaft. If its free try "pinging" the brushes, pull them out a couple of millimeters then let go, make sure the brush is sitting on the comm. Are the lights on your speedo working? does it have any? normally when you give it full throttle an LED will indicate this. If they are not. Reset your speedo (see manual)
pheyhoe is offline
Old 08-17-2006, 12:01 PM
I will cheack the brushes in a minute and so the soldering is on the wrong side of the motor and is bakward? sorry havenever soldered a motor
Old 08-17-2006, 03:07 PM
any 1....
Old 08-17-2006, 03:40 PM
Its not on the wrong side, you just have positive and negative reversed, so if it did run your car, it would go backwards...When you put them on the right way, try pushing the car forward to see if one of your brushes is hung up, if that doesnt work, then make sure the wire coming from your esc to your motor is not damaged or disconnected some how...
BrainMuffin is offline
Old 08-17-2006, 04:07 PM
it doesent evan go in reverse i will open it in the morning
