Best Brushes for Stock Motor >
Old 08-16-2006, 10:45 AM
<TAMIYA_TRF>'s Avatar
Smile Best Brushes for Stock Motor
I have a Epic X Stock motor, and want more performance out of it for racing. Changing the brushes and truing the comm is the way to do it. My question is what kind of brushes should i use?? I have seen some of the Trinity silver laydown stuff, but from what i have heard those are made for longitivity rather than power. Does any one have any suggestions on a really good set of brushes for a stock laydown motor? Also i am using just oil for the bushings on the endbell and the bottom of the can, what does everyone else use?? Thanks
<TAMIYA_TRF> is offline
Old 08-16-2006, 10:53 AM
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
I still like the "F" brushes or Reedy 767s.
Rod
RKeasler is offline
Old 08-16-2006, 10:55 AM
jw92656's Avatar
Smile
The X-Stock motor is a high RPM motor designed for oval racing. I just began testing it, but I would recommend Reedy 767 brushes, and Trinity green/green springs dyno'd to 6.3 ounces (+/-). Oil works just fine for the brass bushings.
jw92656 is offline
Old 08-16-2006, 10:56 AM
Racingfreak6's Avatar
Use f brushes or hurricane gold brushes.You will only get about 2-4 good runs out of them before they drop off.Hurricane gold brushes will get you more life at about the same power.The website is www.teamhurricane.net
Hope this helps
Racingfreak6 is offline
Old 08-16-2006, 02:51 PM
Talking
ok sounds good, i will try out the reedy 767 brushes, thanks
Old 08-16-2006, 09:05 PM
17driver's Avatar
F brush.
17driver is offline
Old 08-16-2006, 10:02 PM
X Stock + F Brushes = Fast.
v0rtex is offline
Old 08-16-2006, 10:13 PM
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
X-stock will be dialed for touring car i think, definately for 12th scale!
Sedan=F Brush, Purple +, Red -
12th-F Brush, Green +, Green -
But depending on the track size and corners, might be better to have a CO27
This track would be dialed for teh X-Stock(My track)
BSchorr is offline
Old 08-16-2006, 10:59 PM
i just bought two pairs of 767 Reedy brushes today at my local hobby shop. what brand makes this "F" brush you are talking about. is it really that much better than the 767 Reedy's? i want the best set up for a race this weekend, its a larger more high speed track which is why im going with the higher RPM motor X Epic. any suggestions???
Old 08-16-2006, 11:08 PM
BSchorr's Avatar
at 2 volts the fbrushes make 1-1.5 more amps then teh 767's. F brushes hold thier serations longer. Finish Line makes the brushes
http://www.finishlinerc.com/
what car do you have, what spur gear do you run and what size are your tires? Foam or RUbber racing?
BSchorr is offline
Old 08-16-2006, 11:38 PM
ok finish line. well i guess i wont be able to get those before the race on this sunday. o well. i have a 415msx stock set up and gearing, im running rp30s.
Old 08-16-2006, 11:43 PM
I wouldnt sweat it too much. There is more time to be made up in your driving than by brush selection in stock
v0rtex is offline
Old 08-16-2006, 11:53 PM
yaaa brush thats very true, ok. thanks for the advice.
i meant to say "yaaa thats very true, ok. thanks for the advice."
Old 08-17-2006, 07:39 AM
17driver's Avatar
That's the truth!!!
17driver is offline
