Anodising Parts
Old 08-15-2006, 05:45 AM
Default Anodising Parts
Just a bit curious about anodising parts and considering doing it to my car.
My understanding is that first the top layer of the metal is stripped by acid and then the process is then applied but my question is whether the removing of the material will make an effect on tollerances ie parts not aligning anymore or is it so minute that there is no problem?
stuartb is offline
Old 08-15-2006, 06:00 AM
santinuchi's Avatar
Default http://mrtitanium.com/anodizing.html
santinuchi is offline
Old 08-15-2006, 06:02 AM
santinuchi's Avatar
Default s
For Gold:
items needed:
1 bowl
simple green
1 pair of alligator clips
tape
your titainium.
7 9 volt batteries
1. connect the 9 volt batteries in series
2. tape the negitive lead to the botton of a dry bowl and attach the other to negitive on the battery
3. fill the bowl with simple green
attach the other aligator clip to the positive side of the battery, and clip on to the titainum.
4. dip half of the titainium in the solution DO NOT touch the negitive lead in the bottom of the bowl, DO NOT put the positive aligator clip in the solution. Will see bubbles from the negitive lead on the bottom of the bowl, when it slows or stops the process is done, flip the TI over and repeat.
Old 08-15-2006, 06:04 AM
santinuchi's Avatar
Default this thread
go to this thread in nitro and electric offroad, it's already a topic, hope it helps, How to get Ti stuff Gold!
Old 08-15-2006, 06:05 AM
santinuchi's Avatar
Default ti
i think only titanium parts can be anodized.
Old 08-15-2006, 06:21 AM
XrayFK's Avatar
That's completely false, almost every car on the market uses anodized aluminum parts.
XrayFK is offline
Old 08-15-2006, 06:31 AM
santinuchi's Avatar
Default ok
as i said I THINK only ti parts can be anodized!!!!!!!!
Old 08-15-2006, 07:54 AM
imprsme's Avatar
Trader Rating: 82 (99%+)
Well MY T2 is not all Ti and it was anodized.... The process you posted is for Ti. But to anodize Aluminum, (which is what ALL cars or made of) is a totally different process.
You will not see any fitment issuses. ALL Aluminum is anodized CLEAR when new, if not you would have to polish it all the time because the oils from you skin would cause it to tarnish/dull.
imprsme is offline
Old 08-15-2006, 07:56 AM
vtl1180ny's Avatar
http://www.caswellplating.com/
vtl1180ny is offline
Old 08-15-2006, 11:30 PM
[[john]]'s Avatar
Trader Rating: 24 (100%+)
Could I Please see a picture of your T2 which has had the allu. anodized. as im thinking about getting mine done red
Cheers, John
[[john]] is offline
Old 08-16-2006, 09:16 AM
imprsme's Avatar
None of these are mine..... But here is a Rainbow of T2's!!!!
http://www.rctech.net/forum/attachme...hmentid=124102
imprsme is offline
Old 08-16-2006, 11:38 AM
Not exactly correct. All aluminum is what's called "mill finish" when it is extruded. Clear anodizing provides a different and more uniform finish than mill finish. The majority of the material is made for purposes other that the exacty shape/profile that it is extruded in. Anodizing stock for machining & other manufacturing purposes makes no cost effective sense.
THE DARKSIDE is offline
