Team Losi JRXS Type-R
#9316
I was looking at the IP5000 on the weekend and it looks like unless they get rid of those bumps they will never fit in the losi. I am interested if anyone has played with the thunderpowers yet.
#9317
well I think I will return it get something else, I guess the Orion 2's fit with no hacking the chassis.
#9326
#9327
#9328
#9329
41 tooth VS 42 tooth front one way pulley.
I recently found that I have been running the 41 tooth front pulley on my one way and it has been very twitchy. Swapped it for a 42 tooth and had to re-tune the car some and it was better/smoother. Is the 41tooth/overdrive change usually reserved for Asphalt? The car was all over the place in a chicane and lost rear grip during off throttle and worse when braking, and now the car is predictable. Running the Haynes IIc carpet set-up with 20lb front springs.
Just some info, share your thoughts too.
#9330
i run a typre R at Tempe in 17.5. the guy i bought my car off had it setup for foam so i have no idea where to go from here. i would be interested to see your setup!
im running a front one way, is it worth it with a 17.5?
