cooked battery
Old 08-14-2006, 07:24 AM
shakzool's Avatar
Angry cooked battery
hi everyone newbie here
can anyone explain how to have a modified car and not cook the battery.
bought myself a msonik 15turn esc and venom 15 d turn motor.
this all ran fine the first few goes on an old 1700 nicd so i toddled of to the lhs cash in hand to get battery with some punch.
i got myself a team orion 2400 nicd ("because they dump the current faster")
as advised buy dude behind counter . this thing got fried and stuffed in about 3 to 4 goes . i put the car in a race situation to give it a good test the pack got that hot i couldn`t hold it . now it holds bugger all charge the bottom 2 cells get the hottest. so now the 15 turn is in the bottom of the spares box.
shakzool is offline
Old 08-14-2006, 12:38 PM
there could be many reasons why.
I would say:
1. check if your gearing is correct
2. check if your drive train is free spinning
3. use a deans connector instead of a "tamiya style" plug (a white plastic shell connector)
there could also be defective cells inside your battery pack. its been a while since nicd 2400 mah batteries were popular, it may be no surprise that these cells were sitting and that some cells may have become defective.
my personal guess would be gearing. Your car may not be properly geared for a 15T motor, because it was using a different motor previously.
rcnewb2004 is offline
Old 08-14-2006, 12:53 PM
Matt Howard's Avatar
did you run the battery 3-4 times in a row (same day?) Nicad's don't like to be run more than once a day.
Matt Howard is offline
Old 08-15-2006, 03:44 AM
shakzool's Avatar
yeh used standard smartech gearing the speir is 47 i think and pinion is 24 .
the car rolls very well so there is no restrictions.
the battery was on special .
i went and got a 19 tooth speir but i think its to late that battery is stuffed and motor as well i put stock back in and bought intellect 3000 nimh that battery i will recomend seems to be very punchy with the stock and lasts ages.
thanks for help.
shakzool is offline
Old 08-15-2006, 03:49 AM
shakzool's Avatar
no matt i ran it twice within a few hours.
mabye cheap motors help cause this it was hot as to.
shakzool is offline
