APS Racing Dyno-Charger S3
hey Guys,
I was thinking about purchasing a new charger. Has anyone used this one before? Also, I would appreciate your feedback on it. Likes, dislikes, etc.
Thanks in advance..
Thanks in advance..
JCB, This is the charger i use, works fine and its pretty simple to use. When you get one you will like it You can change any of the charge settings mid charge (amp rate, cutoff, temp cutoff, mah limit)
The only downsides you can find are no lipo capabilty or discharge. The rest of it is there though.
Thanks for the feedback guys...
Kris, you're going to have it with you on Sat??? would like to see the motor feature.
Thanks kid... see you on sat.
