Sanyo 1300scr problem >
Old 08-12-2006, 10:03 PM
shift's Avatar
Default Sanyo 1300scr problem
I have 3 packs of sanyo 1300scr's and they only charge to 1400-1500 mah and other people seem to get around 1700-1800 out of theres. ive only had the batteries for about 3 months. Any tips on charging,discharging,cycling Thanks for any help
shift is offline
Old 08-12-2006, 10:53 PM
no offence dude but why u running 1300mah?? there up to 4300mah??
but if u really like em some tips are:
check how far u discharge them nicad like to be dead flat so if u can put them on a discharge tray do it and take em down to 0.0v but dont ever discharge a full pack that far only take the cells individually down to 0.0v.
all honesty ud get much better voltage and run time from newer cells imo
hope this helps
aus jd 2703 is offline
Old 08-12-2006, 11:00 PM
loopedeloop's Avatar
We have a 1500Mah limit in stock (silvercan) thats why and we have found these cells to have better punch than the tamiya 1400's that we would otherwise use.
Aus is right, discharge them to 0V ( on a tray) and allow to cool before recharging. Mine take about 1800maH
loopedeloop is offline
Old 08-12-2006, 11:24 PM
shift's Avatar
kool thanks. what should my delta peak cut off be at ive got it at 18mv?
shift is offline
Old 08-13-2006, 01:22 AM
I lat used 1400SCR's in 1994.....
DA_cookie_monst is offline
Old 08-13-2006, 03:21 AM
I have mine at [ edit ]..... make that 140mV for the pack.
Are they getting quite warm by the time they peak??
Old 08-13-2006, 03:46 AM
shift's Avatar
na they hardly get warm when they peak
shift is offline
Old 08-13-2006, 04:09 AM
thecrow2k's Avatar
18mv seems wayyyy low. Put it up to about even 50mv and theyll take in at least another 150mah.
thecrow2k is offline
Old 08-14-2006, 09:33 PM
shift's Avatar
im going to charge the batteries on ctx mode are there any tips at what i should set the Flex's at and what amps to charge at for each step any help would be appretiated. also im in the process of droping the cells down to 0v
shift is offline
