Old 01-26-2003, 06:36 PM   #1
Send a message via AIM to SteveA
Default Getting power out of monsters?
what brushes and springs are people use on thier monster horsepower motor and what are the numbers (amps drawn,RPM, Torq,power,ect.) w/ them brushes and springs if you know them? What is every one doing to get the most power out of them?
SteveA is offline   Reply With Quote
Old 01-26-2003, 08:01 PM   #2
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
I run red springs all around and 4499's; seems about the best for carpet TC...
pimpedaccord is offline   Reply With Quote
Old 01-26-2003, 08:14 PM   #3
popsracer's Avatar
Default monster horsepower motor
The Dyno labels that come on the motors are generally considered to be of little accuracy. I would try to find an Armature with the least amount of balancing done to it. This seems to make for a little more power. In my Dyno tuning on the Monster Stock, I have found that Red springs on both terminals provide an increase in power and torque with a very slight reduction in RPM. Trinity #4499 or Reedy #767 and similar compound brushes seem to work best.
As for overall power, torque, etc. It really is a matter of luck when picking motors as to which ones are better. Gearing is very important to get these Motors to perform at there best. A starting Final Drive Ratio of 7.5 to 8.0 should be good. Adjust from there based on the size of your track and how the motor feels.
popsracer is offline   Reply With Quote
Old 01-26-2003, 08:43 PM   #4
i ran the motors at the carpet race a few weeks ago and i was at 8.2 and it was fast.. i was at a 8.5 but it was not as good as a 8.2.
i was using 767 and red springs on both post.. works great..
teamatlas is offline   Reply With Quote
Old 01-26-2003, 08:47 PM   #5
Neil Rabara's Avatar
Trinity red springs on both poles, and Reedy 767 on (+) with Reedy 766 on (-). I've run the 4499's, but it also depends on the track.
Neil Rabara is offline   Reply With Quote
Old 01-27-2003, 04:10 AM   #6
Trips's Avatar
Trader Rating: 16 (100%+)
For 1/12 4 cell on carpet, the 4499 or 767 with a vertical slot and very slightly narrowed with green springs on both seems to be working well around here.
T
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-27-2003, 04:45 PM   #7
I just tryied some 767 w/ purple springs and got 13 amps @ 3 volts on my turbo 35
Old 01-27-2003, 05:40 PM   #8
skibum989's Avatar
What's recommended brushes + springs for the monster on a tight carpet track about 40x75 with two sweepers (no real straights) about 45-50 feet long? Also what should I start gearing at? (final drive) As you can see by my sig, I'm driving a Losi XXX-SGP on rubber. Thanks for the help!
Ryan Robison
SeattleRCRacers.com - come race with us!
skibum989 is offline   Reply With Quote
Old 01-27-2003, 06:16 PM   #9
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I usually run trinity green on neg, red on pos, axiom 12 full 5 serr brushes.
ski- gear it at about an 8.5, you will have plenty of rip with all the rpm this motor has.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 01-27-2003, 07:38 PM   #10
Trinityracinnut knows whats up I run red, red or green red depending on the track and how the motor feels.
teamAE is offline   Reply With Quote
Old 01-27-2003, 07:50 PM   #11
skibum989's Avatar
Thanks Stephen on the gearing recommendation. I can't get Axiom brushes tho! What would you recommend out of these three:
-Fantom 315
-Reedy 767
-Trinity Crosscuts
Thanks again!
Ryan Robison
Old 01-27-2003, 07:57 PM   #12
has any one tryied the trinity 99 plus?
Old 01-27-2003, 08:13 PM   #13
RandyB's Avatar
i am running sedan stock on carpet and have been running this combo all season
4499 dual shunt on positive side and norm 4499 on neg.
purple springs all around.
2.280 tries
128t 64 p spur
29 pinion
RandyB is offline   Reply With Quote
Old 01-27-2003, 08:21 PM   #14
Send a message via Yahoo to Doug Gaut
I ran some 4505's this last weekend. I was very impressed. The motor had plenty of torque and rpm but the comm wear was much less than I have been having utilizing 767s. I usually get one run before it is time to cut the comm but with the 4505's I got two runs and only had to make one pass with the lathe. The brushes still have serrations too!
Doug Gaut is offline   Reply With Quote
Old 01-27-2003, 08:51 PM   #15
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Steve, if you are still running trucks I would put purple springs on it. The motor has a lot of rpm and not as much torque as some others. You have a lot of tire there to get up to speed and the heavier springs will bring the torque back.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Mini Monsters D_o_S Monster Trucks 23 07-14-2006 11:21 PM
michigan monsters motopro Monster Trucks 0 05-27-2005 10:35 PM
FG monsters ammdrew Monster Trucks 36 02-02-2005 06:49 AM
FS/T:2 Monsters, one MVP Cardboard R/C Items: For Sale/Trade 27 10-17-2004 12:07 PM
Looking for Trinity Monsters... TC3er R/C Items: Wanted to Buy 4 02-02-2004 01:58 PM
