Gear ratio for t2 when switching for 48p to 64p >
Old 08-08-2006, 04:18 AM
Got Xray?'s Avatar
Default Gear ratio for t2 when switching for 48p to 64p
Hi guys i stripped my only 84 tooth (48 pitch) spur gear and all i have now is a 116 tooth 64 pitch spur that came with my car.....and the only 64p pinion i have is a 27tooth......I usually run a 17-18 tooth 48p pinion with my 84 tooth 48p spur.
I will be using my Axiom 27t stock as usual so i was wondering if the 27t (64p) pinion with the 116 tooth (64p) spur will work?
I got the gear ratio for the 27 on 116 and it turns out to be 7.30 so i was wondering if this is within the recommended ratio?
Also i am racing on a track that warrants full throttle 80% of the track.
(Dont tell me about the search function either,i searched heaps and found nothing on T2 gear ratios)
Thanks,
nic
Got Xray? is offline
Old 08-08-2006, 04:21 AM
bizkit1's Avatar
Trader Rating: 27 (100%+)
www.gearchart.com
bizkit1 is offline
Old 08-08-2006, 04:26 AM
Got Xray?'s Avatar
I already went to gearchart....thats where i found out the 7.3 ratio of the
27t PINION-166t SPUR
But what i am wondering is if 7.30 is an alright gear ratio for 27turn racing
But thank anyways
Old 08-08-2006, 05:21 AM
SlamMan's Avatar
I was told gear ratio on stock motors should be in the range of 6-7.5.
What ratio were you running before?
SlamMan is offline
Old 08-08-2006, 05:50 AM
84/17 ratio is 8.4 so is nothing like the ratio you have for 64dp.
You will need something like 118/24 to get the same ratio as your 48dp.
stuartb is offline
Old 08-08-2006, 06:15 AM
[[john]]'s Avatar
Trader Rating: 24 (100%+)
Go To The LHS and Buy A New Spur ?
[[john]] is offline
Old 08-08-2006, 07:01 AM
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
Are you racing Carpet Foam, Carpet Rubber, or Asphault Rubber?
What Axiom Motor is it? CO27?
Then I can tell yo more...
Im thinking ur racing rubber cause with teh average 58mm foam tires, that would be 21.69mm rollout and the is super low!
BSchorr is offline
