Best Pinions / Spurs? >
Old 08-05-2006, 06:38 PM
Default Best Pinions / Spurs?
I am in my second year racing 1/10 sedan.
I've almost got a full set of 48 pitch pinions from Robinson's (the cheap ones). I am at a point with my motor and tuning abilities that I might move up to 64 pitch.
What are the top of the line pinion and spurs?
What are considered the best Bang for the buck?
Any info would be appreciated.
Vincent
CaliberX is offline
Old 08-05-2006, 07:28 PM
hierog's Avatar
I'm partial to TiRacing pinions and Xenon Spurs - they've just worked the best for me. they are a little on the pricey side however. I just bought another TiRacing pinion set 32-39 for $35. Not too bad I suppose
I've also had really good luck with the Speedtech R/C spurs - they work great too!
vic
hierog is offline
Old 08-05-2006, 08:38 PM
geeunit1014's Avatar
Trader Rating: 14 (100%+)
i like the robinson super lite(the purple ones) pinions, and RW or PRS spurs
geeunit1014 is offline
Old 08-05-2006, 09:57 PM
butrflynlambie's Avatar
I have recently purchased a set of the robinson base gears thinking they would be adequate.
What is the main advantage besides weight of upgrading a pinion gear?
butrflynlambie is offline
Old 08-05-2006, 10:41 PM
PitCrew's Avatar
Some pinion gears are made differently than others.
Some pinion gears are "Hobed". You can tell by looking at the involute surface of the gear teeth. If they have a wavy appearance, then those are "Hobed" gears.
Some are "Shaped" gears. They will NOT have the wavy appearance, and generally run with less tooth to tooth error, meaning they are more accurate, run truer, and will make less noise.
PitCrew is offline
Old 08-06-2006, 01:04 AM
gee-dub's Avatar
i've got 2 full sets of 48p and 64p currently. in 48p i am using both the robinson absolutes, which are steel and extremely quiet as well as tir's, which seam to be really loud, but obviously lighter. in 64p i have the robinson purple aluminums, which have been really quiet and fit well on the motor shaft. my only complain is that they seem a bit soft and rocks/debris damage them easily. in all fairness, this is part of the tradeoff with most lightweight materials and finer teeth (64p). recently i have picked up a set of 64p prs pinions. i have been running their spurs on my xray for awhile and have been pretty happy.
gee-dub is offline
Old 08-06-2006, 07:28 AM
Vincent
Jweks makes prabably the best spurs on the market. go to jwerks .com
RW imported from shumacher and PRS are also great. If you race I wouldn't use any other brands.
Juan Aveytia is offline
Old 08-06-2006, 07:41 AM
stiltskin's Avatar
Trader Rating: 103 (100%+)
PRS spurs and pinions. The RW work well too when you need a narrow spur.
stiltskin is offline
Old 08-06-2006, 02:56 PM
JasonC's Avatar
Trader Rating: 120 (100%+)
vic
im pretty sure that the speetech spurs are made by xenon
JasonC is offline
Old 08-06-2006, 07:31 PM
Fred Hubbard's Avatar
Correct and Xenon produces the lightest pinions, with 4 different positions for the grub screw, on the market.
EDIT: Here are links for both 48 and 64 pitch Xenon pinion gears:
Xenon 48p Pinion Gears
Xenon 64p Pinion Gears
And I neglected to mention that ONLY Xenon makes a gear in every tooth for their spur gears. Which can also purchased through Speedtechrc.
Xenon 48p & 64p Spur Gears
Fred Hubbard is offline
Old 08-06-2006, 10:16 PM
CHRIS CHAVEZ's Avatar
My vote's for xenon!!!
CHRIS CHAVEZ is offline
Old 08-09-2006, 08:07 PM
Trader Rating: 44 (100%+)
if you only have metric tools, then my vote is for Kawada. best bang for bucks.
robinson pinions are nice .. but u need imperial tools.
wyl03 is offline
