-   -   DIY RC stuff (https://www.rctech.net/forum/electric-road/123937-diy-rc-stuff.html)
Drewdc90 08-02-2006 02:00 AM
DIY RC stuff
2 Attachment(s)
Has anyone made something for their RC car or pit equipment that they would like to share with rest of us?? Something that you could not buy elsewhere, or was too expensive, or just wanted to make so you could say that you made it yourself.
Here is an example of something that I made because the original was too expensive and I needed it to do more than one job. This is a tyre warmer voltage controller (controls tyre temp) that allows me to put anywhere from 4v to 12v into the tyre warmers. It also can run the Johson 540 motor on my Team Cobra lathe and can vary the speed if need be. And it can also alllow me to run in my stock motor. Here is a pic of the first and second efforts.
It can be anything practical, not just electrical.
XrayFK 08-02-2006 02:14 AM
I've made my own motor coolers and power supplies. Just for fun basically.
http://rctech.net/forum/attachment.p...hmentid=119500
http://rctech.net/forum/attachment.p...hmentid=119502
DA_cookie_monst 08-02-2006 02:15 AM
power supply(s)
Cell coolers
shock towers
chassis's
topdecks
the list goes on
chicmagnet 08-02-2006 02:21 AM
can you pls post a pic of your motor cooler??? im planning to build one... :blush:
XrayFK 08-02-2006 02:28 AM
I don't have any pics on this computer, but send me a PM and I will help you out.
Vance 08-02-2006 03:31 AM
1 Attachment(s)
Hey guys,
GREAT forum idea this. Regarding this PC power supply above. I have detailed instructions to build your own. Unfortunately the doc doesn't indicate a voltage pot, but it does allow for 12volts & 5volts respectively.
I got the doc yonks ago in the net ... if you want it, see attached.
Enjoy!
Carbonator 08-02-2006 07:35 AM
Hey Guys,
How about designing and building your own car???
http://img.photobucket.com/albums/v6...bonizer/12.jpg
What do you say about that?
Regards
RA
andrewtexas123 08-02-2006 07:41 AM
that looks awsome :eek: keep up the good work :tire:
bizkit1 08-02-2006 08:05 AM
So I guess your sponsered by....yourself? :rolleyes: Nice job, good to see those CNC/Machinist skills put to good use :sneaky:
aoizip 08-02-2006 12:32 PM
just wondering for people who design their own chassis and part.
What software are you guys using?
Autocad / Power Mill etc?
~Ming
bizkit1 08-02-2006 01:07 PM
aoizip-I personnally use Surfcam 2003, you can draw it up and post process(g code) to the machine that you have. You can use Autocad to draw it up, but you still have to generate code. I've made Tamiya Bruiser lower shock mounts, battery heatsinks, and numorous odds and ends for my car and others. You would be surprised at how much you can shave off of a gear or other areas of your car to free up some weight. :nod:
Drewdc90 08-02-2006 02:14 PM
Originally Posted by Carbonator
Hey Guys,
Regards
RA
Well done. I guess you cant do better than that when it comes to DIY.
How long did it take you from design to completion? How well does it drive?
protc3 08-02-2006 03:43 PM
we use gibbscam for our cad drawing and post processing.very simple yet powerful system.we do alot of our developement on gibbscam and also with autocad.
seth556 08-02-2006 08:49 PM
I've done a lot of cutom fab for my rustler. Nows its a 2wd truggy style truck with an odd looking rusty body.
http://www.ultimaterc.com/forums/showthread.php?t=65522
http://img.photobucket.com/albums/v3...y/100_0990.jpg
BTW if you look at the thread you'll see that I've changed the wing to something good looking.
PeteB 08-02-2006 09:47 PM
Originally Posted by Drewdc90
This is a tyre warmer voltage controller (controls tyre temp) that allows me to put anywhere from 4v to 12v into the tyre warmers. .
Drew, what were the specs on the pot you used. I also made up some tyre warmers, but the lowest resistance pot i could get was 500ohms, which when putting in 12v, means that it cuts the voltage down to zero with only a few mm of turning the pot. so I have been running the warmers off my charger, which is not ideal, as I want to peak the pack at the same time that the warmers are doing their thing.
thanks
Pete
Content © 2001-2011 RCTech.net
