Old 08-06-2006, 03:18 PM   #91
mistercrash's Avatar
R/C Tech Charter Subscriber
I did so much stuff for myself in this hobby that I can't remeber them all. Here's a few.
Home made tire truer I did many years ago.
Modified front suspension on a HPI Super F1
Custom made chassis and parts for a HPI Micro RS4
Custom made chassis and parts for a Tamiya F102
Tweak station
Home made top plate and parts for a Mugen MTX3
Retractable landing gears on R/C airplanes that were not designed to have them.
I did other stuff but I can't find pics of them.
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 08-06-2006, 03:37 PM   #92
Send a message via ICQ to rcnewb2004
Nice Work Mistercash!
rcnewb2004 is offline   Reply With Quote
Old 08-06-2006, 04:01 PM   #93
nordheim's Avatar
Originally Posted by Vance
Hey guys,
I reckon the idea with the peltier cooler is too zero-cool your motor just before you race, correct? I'm sure that a permanent mounted peltier while racing will be more effective, but the question is how to power it ... from battery, eating the actual motor power?!?!? I would like to hear your comments.
What I am still doing now is too soak a chamois (sheep-skin-cloth used to dry your car after washing) glove (cut-out and sown up to fit the motor with the vents open) with water and spray it generously with nitro-freeze (I get it canned from electronic shops) just before you race. The motor is still very hot after a race, but it gives you the extra few mm's when needed to cross the finish line.
On another subject guys : On 540 silver can Johnson Stock motors : Still today I use my rubbing compound, brasso, luke warm soapy-water to run-in the brushes on these motors and get the max out these motors. Do you have any other tips to share?
Cheers.
The peltiers will suck a lot of power out of your battery. Unless you can find a secondary power source, it will be tough for runtime.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 08-06-2006, 04:09 PM   #94
Drewdc90's Avatar
I've heard of small lipo batterys being used to power onboard peltiers.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 08-06-2006, 05:00 PM   #95
XrayFK's Avatar
Lipo batteries that are small enough to fit in a sedan are around 200mah and rated at 5C, nowhere near enough to power a peltier. There's also the extra weight from the peltier, clamp, and heatsink/fan to keep the peltier cool. Even if you somehow managed to get all of that fitted in there and a working onboard power source, it would outweigh any benefits that it gave.
XrayFK is offline   Reply With Quote
Old 08-06-2006, 05:05 PM   #96
Drewdc90's Avatar
Mistercrash. Love your work. This is what I like about DIY and RC. We think out of the box for solutions and ideas. Keep the ideas rolling in. Good or bad I think we can all appreciate the time and effort put in.
Old 08-06-2006, 05:11 PM   #97
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
Tweak station
nice tyre truer....wat grinds away at the tyre?
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 08-06-2006, 07:00 PM   #98
XrayFK's Avatar
Do you see the white thing right by the tire? I'm guessing it's that.
Old 08-07-2006, 01:32 AM   #99
Vance's Avatar
Mistercrash ... nice work. Tell me, what tools 7 machinery did you use to make all these? Also, what did you use to design them (i.e. CAD, etc..)?
Thanks!
Vance is offline   Reply With Quote
Old 08-07-2006, 02:08 AM   #100
yeah im guessing its that white thing too
i made a chassis for my mini t out of plywood as a prototype....its fully crazy lol
HIP Baja 5sct
Old 08-07-2006, 04:06 AM   #101
heres my lastest project....TFmT ... Top Fuel Mini T
its a mini t rear end with novatech 25amp speedy,himark 5400kv motor and i took 5 cells off the pack because i installed a proper dragster front end thats been savaged from my old nitro blaster..
i was running 13 cells then i ran 10 cells n now im running 8 cells....with 10 cells its insane...
the chassis is from plywood..(cheap protoype material HA!)..the proper chassis (if i dont get sick of it) will be from 2.5-3mm carbon fibre sheet and will be slightly longer
im running 1/10 scale axels in the back with 45mm foam drag slicks
HIP Baja 5sct
Old 08-07-2006, 11:01 AM   #102
Thanks!
I used a few tools that I dug up in Archeology class. A "Hacksaw" and a "file". To design everything, I used three things that you young people hardly ever saw before. A pencil, a ruler and paper
Old 08-07-2006, 03:51 PM   #103
MK_Arbiter's Avatar
Hey, mistercrash, how did you build that truer? I need a truer, but I don't have 200$ to shell out.
MK_Arbiter is offline   Reply With Quote
Old 08-07-2006, 04:15 PM   #104
I got help for that truer from a machinist. Mostly made out of aluminum stock with a couple of steel tubing, brass sleeves, bearings and threaded rod. A small brass pulley was made for the motor shaft and a plastic pulley for the shaft that the wheels mounted on. A big fat O ring served as a belt.
Old 08-07-2006, 08:48 PM   #105
dude can u post some more piks of ttyre truer? lol i wana try make 1
HIP Baja 5sct
various stuff...LST Stuff, Trinity Battery case, MINI-T Pro, Vendetta Stuff, cleaning mach51 R/C Items: For Sale/Trade 1 03-06-2008 10:14 AM
all my stuff for sale: xbox 360, halo3, pc stuff, games, illegal firearms O.O LKMAO tony 06 Other Items: For Sale/Trade or Wanted to Buy 41 01-19-2008 01:15 PM
Some Revo Stuff... Some Mini-T Stuff... Misc. Stuff... Mallanaga R/C Items: For Sale/Trade 39 08-28-2007 10:30 AM
Sell-Out, PRO stuff, New stuff, Old stuff - CHEAP FreqETag R/C Items: For Sale/Trade 32 03-17-2006 08:54 AM
wanted 12th scale stuff, xxxs stuff, ntc3 stuff primusblowsgoat R/C Items: Wanted to Buy 6 03-25-2005 11:18 AM
