Old 08-04-2006, 10:35 PM   #76
Drewdc90's Avatar
Originally Posted by nordheim
Home depot or Lowe's. 1 1/4" coupling. Perfect when you split it down the middle.
Thanks for that, I'll have to look out for it.
Drew.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 08-05-2006, 01:44 AM   #77
XrayFK's Avatar
Originally Posted by Tpg racer
About glueing the copper plate to the peltier device, what would happen if I did not used thermal bonding. Instead I use normal super glue and I only glue the plate at the corner end of the copper plate.
That would leave the center part of the copper and peltier device clear of glue and so on.
Would that work???
You wouldn't want that, you WANT to use the thermal epoxy as it helps transfer heat by filling in the microscopic air gaps between the two plates.
XrayFK is offline   Reply With Quote
Old 08-05-2006, 01:50 AM   #78
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
it cant make that much of a difference can it??
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 08-05-2006, 02:12 AM   #79
Tpg racer's Avatar
yea will it make that much of a difference???
Wouldn't a contact between the peltier and the copper plate directly is better than a contact with adhesive in the middle layer???
Tpg racer is offline   Reply With Quote
Old 08-05-2006, 05:52 AM   #80
the adhesive will prolly make it perform like 10% better...
HIP Baja 5sct
Old 08-05-2006, 06:37 AM   #81
volracer's Avatar
Send a message via ICQ to volracer
Many years ago, a friend and I made a cell discharger with A/D converter, which connected to the joystick port of an Atari computer. The computer read the signal, sampled it and graphed. We could store the data and compare it.
volracer is offline   Reply With Quote
Old 08-05-2006, 07:44 AM   #82
XrayFK's Avatar
If you think it won't matter then don't use it, let me know how it works out.
Old 08-05-2006, 07:46 AM   #83
XrayFK's Avatar
To the first question yes, no to the second.
Old 08-05-2006, 08:08 AM   #84
PerformanceRC's Avatar
how do you power the peltier motor cooler?
PerformanceRC is offline   Reply With Quote
Old 08-05-2006, 08:11 AM   #85
XrayFK's Avatar
DC power supply, most peltiers operate at 12-15v.
Old 08-05-2006, 04:18 PM   #86
rchoudini's Avatar
rchoudini is offline   Reply With Quote
Old 08-05-2006, 04:20 PM   #87
nordheim's Avatar
Regular glue wont work for 2 reasons;
1. It wont handle the extreme heat/cold temperatures.
2. It will not transfer the cold from the peltiers to the clamp as the Thermal Epoxy is the main reason for this process. I seat the clamp in a fair layer of thermal epoxy for durability and effectiveness.
You would be wasting your money and time not to do it right.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 08-05-2006, 06:19 PM   #88
i dont even know wat this thing is....but by the piks it looks like a realy good can cooler....i think ill make 1
HIP Baja 5sct
Old 08-06-2006, 02:41 PM   #89
Vance's Avatar
Hey guys,
I reckon the idea with the peltier cooler is too zero-cool your motor just before you race, correct? I'm sure that a permanent mounted peltier while racing will be more effective, but the question is how to power it ... from battery, eating the actual motor power?!?!? I would like to hear your comments.
What I am still doing now is too soak a chamois (sheep-skin-cloth used to dry your car after washing) glove (cut-out and sown up to fit the motor with the vents open) with water and spray it generously with nitro-freeze (I get it canned from electronic shops) just before you race. The motor is still very hot after a race, but it gives you the extra few mm's when needed to cross the finish line.
On another subject guys : On 540 silver can Johnson Stock motors : Still today I use my rubbing compound, brasso, luke warm soapy-water to run-in the brushes on these motors and get the max out these motors. Do you have any other tips to share?
Cheers.
Vance is offline   Reply With Quote
Old 08-06-2006, 03:14 PM   #90
http://www.svc.com/arsiltherad.html
thermal paste epoxy
kinda expensive, but so is everything else in RC
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
various stuff...LST Stuff, Trinity Battery case, MINI-T Pro, Vendetta Stuff, cleaning mach51 R/C Items: For Sale/Trade 1 03-06-2008 10:14 AM
all my stuff for sale: xbox 360, halo3, pc stuff, games, illegal firearms O.O LKMAO tony 06 Other Items: For Sale/Trade or Wanted to Buy 41 01-19-2008 01:15 PM
Some Revo Stuff... Some Mini-T Stuff... Misc. Stuff... Mallanaga R/C Items: For Sale/Trade 39 08-28-2007 10:30 AM
Sell-Out, PRO stuff, New stuff, Old stuff - CHEAP FreqETag R/C Items: For Sale/Trade 32 03-17-2006 08:54 AM
wanted 12th scale stuff, xxxs stuff, ntc3 stuff primusblowsgoat R/C Items: Wanted to Buy 6 03-25-2005 11:18 AM
