Old 08-03-2006, 05:13 PM   #31
PeteB's Avatar
Has anyone had a go at making some sort of dyno?
I have had a go of sorts... but i'm not sure if the results I am getting are right.
basically I hooked up the motor being tested to 1v and a slave motor, and then measure the amps that the slave motor is producing.
Based on Ohms law... Power = volts x amps
if I input 1 volt to the motor being tested and the slave motor that is being turned by the test motor is producing 4 amps, does that mean that (less any losses) that the motor being tested is producing 4 watts??
Pete
JRXS-R
GTB SS + 13.5 & 10.5
Trakpower 4900
Supernova
Nomadio
PeteB is offline   Reply With Quote
Old 08-04-2006, 01:18 AM   #32
nordheim's Avatar
I have made both Power Supply Distribution Boxes and Motor Coolers.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 08-04-2006, 01:34 AM   #33
Tpg racer's Avatar
Hey there, I was thinkin about makin a motor cooler but the peltier device is just hard to find here in Malaysia.
So I was thinkin about makin motor cooler by using copper tube wrap around the motor and having icy cool water flowing inside the copper tube.
I know that this is not very high tech and wouldn't bring the motor down to a chilly tempereature but I think it would work.
Tpg racer is offline   Reply With Quote
Old 08-04-2006, 02:37 AM   #34
if u could get liquid nitrogen thats super cold but i dont know any one who knows where to get it.
but wouldnt it bo cool
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 08-04-2006, 03:04 AM   #35
PeteB's Avatar
pic of the tyre warmers...
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 08-04-2006, 03:22 AM   #36
MK_Arbiter's Avatar
How did you make those?
MK_Arbiter is offline   Reply With Quote
Old 08-04-2006, 03:40 AM   #37
PeteB's Avatar
combine 1 pair of old jean with a pair of scissiors, trim
toss in 4m of cuprothol, 4m of audio speaker wire, solder in parallel
combine with a sewing machine, and apply power
draws 10amps and gets to 70deg c in about 3 min.
Yeehaa!
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 08-04-2006, 03:47 AM   #38
PeteB's Avatar
sorry, just my humourous side...
I take absolutly no responsibiliy if you stuff this up. burn yourself etc. I burnt myself several times, and have burn lines on my hands to proove it.
NOT recommended for kids!! You have been warned!!
ok... ready? cut 4 denim rectangles out of old jeans, about 10cm wide, and 15 cm long
next thing is to find out how much resistance wire to use, i used about 75cm of cuprothol per warmer, apply 12v to the 75cm length and it should get hot to touch, but not hot enough to burn the denim.
sew about 75cm of cuprolthol wire into 4 lenthwise 'sleeves' up and down the denim so that it cannot touch itself, twist and solder on about 40cm of speaker wire
do this 4 times
then solder all the positive ends of the speaker wires together and insulate well, do the same for the negatives then apply a small amount of power, see how hot it gets, increase power as you see fit.
it is a bit tricky, and you must use a sewing machine, otherwise it will take FOREVER.
I'll be making another, better set soon... will post any improvements
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 08-04-2006, 03:52 AM   #39
itchy b's Avatar
Originally Posted by PeteB
sorry, just my humours side...
no, really, cut 4 denim rectangles aout of old jeans, about 10cm wide, and 15 cm long
sew the cuprolthol wire into 4 lenthwise 'sleeves' up and down the denim so that it cannot touch itself, twist and solder on the speaker wire
do this 4 times
then solder all of these together and insulate well, then power it up
cut up the jeans ONLY IF THE'RE NOT LEVIS as you should get a couple of decades more wear from them!!!
seriously peter, nice work to come up with a cheap alternative
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-04-2006, 03:54 AM   #40
Drewdc90's Avatar
[QUOTE=nordheim]I have made both Power Supply Distribution Boxes and Motor Coolers.
Like the boxes, but Love the cooler even more. I have tried the same but cannot get the device lower than 16 degrees C let alone form ice. Can you post details of have you built it??
And love the tyre warmers Pete.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 08-04-2006, 04:02 AM   #41
PeteB's Avatar
Yeah man, stuff paying $200 for a set of warmers that tells you how hot the tyres are...
this costs about $10, not including the digital thermometer, which was $30
mind you, it might be cool having "Red Tab" or "501" warmers...
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 08-04-2006, 04:04 AM   #42
XrayFK's Avatar
The reason you can't just pick some up off the shelf is because nitrogen is a gas at room temperature. A good thermos flask can be used to store liquid nitrogen for one to two days, as it will keep it cold and won't get destroyed as the nitrogen is poured in (-196C). You'd have to ask somewhere that stores a large quantity of liquid nitrogen if they have any to spare. Hospitals/mortuaries, physics labs, cyronics labs, or fruit freezing facilities.
XrayFK is offline   Reply With Quote
Old 08-04-2006, 04:21 AM   #43
PeteB's Avatar
heres a pic of my attempt at a basic slave motor dyno, not a great pic, but I had some space in my powerbox, so i put an old stock motor in it, using a universal joint to connect the motor being tested and then putting in 1v via my charger, and then reading the results on a voltmeter.
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 08-04-2006, 04:41 AM   #44
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
i have made a mini t rollcage,a custom funny car chassis for my dragster and the best thing i have made is for my savage...its a blower that has real functioning blowers on it....press the throttle and the red circles flip back... ill post some piks soon
cant think of any other stuff right now....im always doing different things lol
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 08-04-2006, 06:03 AM   #45
XrayFK's Avatar
Pete
Have you measured the voltage output?
various stuff...LST Stuff, Trinity Battery case, MINI-T Pro, Vendetta Stuff, cleaning mach51 R/C Items: For Sale/Trade 1 03-06-2008 10:14 AM
all my stuff for sale: xbox 360, halo3, pc stuff, games, illegal firearms O.O LKMAO tony 06 Other Items: For Sale/Trade or Wanted to Buy 41 01-19-2008 01:15 PM
Some Revo Stuff... Some Mini-T Stuff... Misc. Stuff... Mallanaga R/C Items: For Sale/Trade 39 08-28-2007 10:30 AM
Sell-Out, PRO stuff, New stuff, Old stuff - CHEAP FreqETag R/C Items: For Sale/Trade 32 03-17-2006 08:54 AM
wanted 12th scale stuff, xxxs stuff, ntc3 stuff primusblowsgoat R/C Items: Wanted to Buy 6 03-25-2005 11:18 AM
