Old 12-04-2006, 11:10 AM   #151
TEM
TEM's Avatar
Originally Posted by builthatch
i also am severly interested in this type of info. in another thread, i asked-
"I use a Trinity D-90 for my IB4200's, but i want to cycle my IB750 AAA's that i use for my mini-z and the products that are out there, such as the PN Racing discharger board are of inconsistent quality and function.
I have a nice digi multimeter and some ability. I know there has to be something in writing on how to use maybe some bulbs, resistors, diodes, a pot and some breadboard to make a nice discharger.
Is there anything out there that i can make that would have a 1amp discharge rate and cutoff at .9 or .7 volts, individually? I'd like to do 4 cells at once time, but bring each down individually to the cutoff voltage.
thanks!"
The circuit is VERY simple!, don't use diodes, use an opamp circuit to do the monitoring of the voltages and is much more accurate and you can calibrate it to the voltage you want. A mosfet can be your "switch" to a load resistor.
TEM is offline   Reply With Quote
Old 12-04-2006, 12:27 PM   #152
builthatch's Avatar
Send a message via AIM to builthatch
hmm, is there a schematic available for this type of setup? I have a very limited knowledge of specialized electronic bits, but i am very adept at soldering and have a basic knowledge of electric theory and application.
I am very interested in building this.
5'16", 154.2 kg
builthatch is offline   Reply With Quote
Old 12-04-2006, 01:11 PM   #153
TEM
TEM's Avatar
I'm looking for data on what frequency and wave form is good for pulse discharging IB's at 30amps so I can then draw my own schematics. Honestly if you found a couple books on electronics and read about mosfets or biasing transistors you can design your own. Also, do a google search on ESC schematics and you can rip from that! Also look for opamp voltage monitor or voltage comparators and it's self explanatory. You will need to calculate some resistor values and calibrate the circuit to work on the voltage you want to trip at.
Old 12-05-2006, 12:36 AM   #154
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
some of you guys on the previous page said that silver compound is expensive? i bought a 5g tube i think which is 25% silver....i think thats enough dont u think? lol......for about 6 bucks at jaycar..
www.jaycar.com.au
i am still curious how to get frost.....AND on the COLD side of the peltier around 1/4 of the peltier on the corner that the black lead is connected it gets hot? not cold? is this normal?
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 12-05-2006, 02:25 AM   #155
Speedie's Avatar
I found the schematics for the equalizer tray I made some time ago. I got the plans from a site called Sanj's Yokomo RC Homepage that doesnt exist anymore that I know of so I dont think hell mind me posting them. I got plans for a few other things off of there too If I can find em. I know one was tire warmers Ill have to find that one for ya all. I bought everything from Radio Shack and I do remember I used 2 diodes to speed up the discharge time. The first page is a simple tray without LED's the rest is a tray with LED's. I had an old shell from a trinity tray I used worked sweet. Tray cuts out at .6v
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 12-05-2006, 02:27 AM   #156
Speedie's Avatar
heres a top pic
Old 12-05-2006, 05:54 AM   #157
b3buggy's Avatar
www.jaycar.com.au
Regarding silver, we were talking about material for the clamp.
No that is not normal, Although if the hot side get too hot your peltier could get overwhelmed and it will all start getting warm.
What is the spec of the peltier? are you running it at the correct voltage?
Make sure the peltier is seated correctly onto the heatsink with thermal compound.
RCR Racing - Worcester MCC
b3buggy is offline   Reply With Quote
Old 12-05-2006, 11:27 AM   #158
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Actually, it's the thermal adhesive that's expensive.. thermal compound in the $5 tube is much cheaper, but is like grease and won't help keep it together.
B3Buggy is right about the 'warm' corner of the cold side.. make sure every bit of the surface is compounded and in contact with the heatsink.
Also, I've had a peltier dropped on the ground and it started doing that to a corner near the wire as well. Clamping it too tight can also cause this, as I've found.. Needless to say I've been though 3 or 4 peltiers in the past few years..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 12-06-2006, 12:22 AM   #159
the thermal compound i got from jaycar works realy good.......and its pretty hard to pull the parts apart unless u slide em apart....which is still abit hard..
has ne1 thought bout making their own dyno? like a real size dyno......but a small 1 to test fuel mixtures etc...since u cant turn on radios in the pits u can chuck the car on a dyno and stuff around with the fuel mixtures while the car is stationary.....
HIP Baja 5sct
Old 12-29-2006, 03:14 PM   #160
b3buggy's Avatar
Cool Battery Box
Hi guys,
Just finished this battery box, has got 5 cells (6v) to power our tyre warmers while taking them to the track, or anything else(comm lathe etc.)
Has got my Brother's paint scheme on the lid .
Only a simple little thing.
Ross
Old 12-29-2006, 04:12 PM   #161
shaggys40oz's Avatar
Custom tire warmer
I have some RC cars and other stuff.....shaft drive forever!!
shaggys40oz is offline   Reply With Quote
Old 09-16-2007, 06:56 AM   #162
birdy's Avatar
can someone post instructions on how to make a power distribution box
thanks
birdy is offline   Reply With Quote
Old 09-18-2007, 02:06 PM   #163
birdy's Avatar
anyone got any instructions
Old 11-23-2007, 11:48 PM   #164
Drewdc90's Avatar
Anything new someone has made lately???
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 11-24-2007, 12:42 AM   #165
more$thanbrains's Avatar
Send a message via MSN to more$thanbrains
i made a crap
il post pics of my buddy's table/cart/bench tomoro
Xray~Titan~Ko Propo~Orion~Muchmore~Dekelz.com
T2 007 US/EU~CRC Gen-XL~MO3-Pro~NT1~Corally C10X
'73 Ford Bronco sittin on 36" swampers~ 10" lift
more$thanbrains is offline   Reply With Quote
various stuff...LST Stuff, Trinity Battery case, MINI-T Pro, Vendetta Stuff, cleaning mach51 R/C Items: For Sale/Trade 1 03-06-2008 10:14 AM
all my stuff for sale: xbox 360, halo3, pc stuff, games, illegal firearms O.O LKMAO tony 06 Other Items: For Sale/Trade or Wanted to Buy 41 01-19-2008 01:15 PM
Some Revo Stuff... Some Mini-T Stuff... Misc. Stuff... Mallanaga R/C Items: For Sale/Trade 39 08-28-2007 10:30 AM
Sell-Out, PRO stuff, New stuff, Old stuff - CHEAP FreqETag R/C Items: For Sale/Trade 32 03-17-2006 08:54 AM
wanted 12th scale stuff, xxxs stuff, ntc3 stuff primusblowsgoat R/C Items: Wanted to Buy 6 03-25-2005 11:18 AM
