Old 07-09-2007, 04:46 PM   #1456
kuzo's Avatar
Send a message via MSN to kuzo
Originally Posted by GymBeam View Post
why would you need to specify a 90% capacity for, because the ICE will "peak" one it reaches 8.4V @ 0.10a
I think he recommended it as an additional safety measure. This way if due to a random glitch the charger does not stop properly it will cut off before it gets too far.
kuzo is offline   Reply With Quote
Old 07-09-2007, 04:56 PM   #1457
GymBeam's Avatar
Originally Posted by Unregistered View Post
You can't really cycle LiPo's like you cycle out a NiMh cell/pack. Well, you can but the numbers will not be very good. I don't think they like a high current constant discharge.
My 3200 works fine on the track and that's all that matters for me.
Isnt High current cosntant amp draw, what gives your car the top speed along the straight you need?
not knocking it but looking at the discharge curve, i cant see how the 3200 lipo can match up to IB3800, let alone 4200WC's, unless one was to run the car 200gram lighter
GymBeam is offline   Reply With Quote
Old 07-09-2007, 05:04 PM   #1458
MikeXray's Avatar
Trader Rating: 73 (100%+)
Here is a page from the trakpower information PDF with 30a curves.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-09-2007, 05:20 PM   #1459
sportpak's Avatar
Trader Rating: 26 (100%+)
Are you oval racing with this thing? I know oval guys stress over every last penny when it comes to graphs and things. I've been running them for a while now, and honestly, I don't feel down on power. Gear up a tooth and wheel it.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 07-09-2007, 05:40 PM   #1460
My 3200 also came with the case split like yours. you could easily pull them apart and see inside. I just pressed fairly hard on the half's and the tape stuck really well after that.
Don't discharge you lipo pack any more, you don't need to. Just charge and run it!
gezer2u is offline   Reply With Quote
Old 07-09-2007, 05:44 PM   #1461
GymBeam's Avatar
thanks for that pic. i do agree with the LiPo discharge curve.
But the IB4200 Curve just isnt representative of a good IB pack. at 100sec its already at 6.25v? and only total 6.13Avg voltage?
and look at 110sec the IB discharge curve starts going up, that normally happens when the IB pack has been left sitting around unused for months on end, and IR has gone up.
I do agree though that the lipos do have better voltages near the tail end. thus giving better run time.
my opinion, the Orion3300's great for bashers and people who want maintenance free playing, and those who dont have to worry about weight limits or balancing the car, but for racers who want voltage, Nimhs are much better.
Old 07-09-2007, 07:15 PM   #1462
syndr0me's Avatar
Trader Rating: 32 (100%+)
The voltage thing really only matters when comparing the two directly, and is NiMH's only merit, if you want to call it that. If you're racing in a mixed environment, and the track is flexible enough to let you play with different batteries, you can probably get away with shedding a few ounces too, which more than makes up for anything you might lose with a little voltage. Also, the voltage game means a lot less in mod than it does stock and 19T, especially in places like off-road. Some classes value run time over voltage, which LiPo has in spades. In truth, the only place it may be at a disadvantage is in stock and 19T sedans with old weight limits in place. That's not the majority of racing these days.
Also, people have pointed out that the safe cells Orion uses are relatively low on the voltage side compared to others. You could experiment with the TrakPower/Enerland cells, or the MaxAmps/UnknownChineseOrigin cells for more voltage, perhaps, though likely giving up some safety and cycle life in the process.
syndr0me is offline   Reply With Quote
Old 07-10-2007, 06:35 AM   #1463
kuzo's Avatar
I've done my first cycle on the Lipos....
I'm a bit concerned about the numbers....
I charged them up and then did a discharge cycle.
Charger Settings 20 amps, 6.6V cut off.
My results for the Orion 3200 was, DIS 2272mah, 6.955v Average Voltage, 33 IR
(For reference Comparing this to my IB3800 Pack i got
Dis 3021mah, 7.260v Ave Voltage, 30 IR)
Check out this info from the Platinum thread regarding comparing lipos during low amp discharging: http://www.rctech.net/forum/showpost...postcount=1144
Old 07-10-2007, 10:19 AM   #1464
jag88's Avatar
I have to agree with Gymbeam. That IB graph is TOTALLY wrong. IB cells are really bad with one cell (or more) being bad right out of the box BUT if you get 6 cells that are good or even average then the discharge curve is WAY better then what is shown on that graph !
jag88 is offline   Reply With Quote
Old 07-10-2007, 11:29 AM   #1465
sportpak's Avatar
Cool, so I'll keep buying IB cells every month to maintain that slight advantage that only matters to top 3% national level drivers and professional bench racers.
I like knowing what I have, every run, every cycle, every 100th cycle. Stay off the boards two less times a run and you more then made up for that graph.
Old 07-10-2007, 11:53 AM   #1466
kuzo's Avatar
Take a look at this from the link that linger had provided: http://www.slowflyer.ch/downloads/tn06003v2.pdf
In figure 1 they show the pack capacity and voltage per cell charted from over 200 cycles with a Kokam 4800 mAh 3S1P pack. Flat as a board for over 200 runs. Imagine buying a pack and knowing you are going to get the same performance out of it for 200 runs as opposed to hmmm....10 maybe. The testing was done at nearly 60 amps as well.
Old 07-10-2007, 12:03 PM   #1467
syndr0me's Avatar
In figure 1 they show the pack capacity and voltage per cell charted from over 200 cycles with a Kokam 4800 mAh 3S1P pack. Flat as a board for over 200 runs. Imagine buying a pack and Knowing you are going to get the same performance out of it for 200 runs as opposed to hmmm....10 maybe. The testing was done at nearly 60 amps as well.
It's unfortunate that LiPo is being judged on its voltage vs. NiMH, but that's what's going to happen. I'd say the answer is to shed a few oz to make up for it if you find yourself having trouble.
Old 07-10-2007, 02:18 PM   #1468
tallyrc's Avatar
sure, for like 10-20 runs, then it's a $60 dollar practice pack..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 07-10-2007, 02:19 PM   #1469
I can't think of a single class that has a constant current draw. A huge oval might get close.
In any case, all I'm saying is that I don't think that the LiPo cells like a constant discharge rate like the NiMh cells do. I would rather let the lap times tell the story than a discharge curve.
Power {(amps X voltage)-Efficiency} is what gives you that speed on the straight. Less voltage and you need more current. More voltage and you need less current.
Unregistered is offline   Reply With Quote
Old 07-11-2007, 01:39 PM   #1470
SoCalMitch's Avatar
Did not know where else to put this but here is an Orion charger and a Novak 4.5 amp power supply. Got tired of carrying around a bigger power supply the the charger.
Team Orion 3200mAh Race Spec LiPo-dsc00881.jpg   Team Orion 3200mAh Race Spec LiPo-dsc00882.jpg   Team Orion 3200mAh Race Spec LiPo-dsc00883.jpg
SoCalMitch is offline   Reply With Quote
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
