Old 06-19-2007, 09:42 PM   #1381
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by knapster View Post
Does anyone know for sure who to contact if you believe you've bought a defective 3200 lipo? My LHS is even having a hard time with this.
I typed Orion RC into google and in a mater of seconds I came up with the following . . .
http://www.teamorion.com/Contact
Thats where I would start.
Old 06-20-2007, 02:13 PM   #1382
chris72983's Avatar
When will the weighted lipos come out? So when can quit having add all that lead to get the cars up to weight and balanced out.
chris72983 is offline   Reply With Quote
Old 06-20-2007, 02:29 PM   #1383
MrBlack's Avatar
We may have something better
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 06-20-2007, 02:51 PM   #1384
sportpak's Avatar
Trader Rating: 26 (100%+)
Nobody likes a tease!
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 06-20-2007, 03:03 PM   #1385
MrBlack's Avatar
Tell that to the soft core porn industry
Old 06-20-2007, 04:08 PM   #1386
sportpak's Avatar
Who actually supports soft core porn?
Ahhemmm!! Loving the batteries. TC gets better with testing. Buggy is still a squirrel, but fun. Love leaving the big tub o'crap for Mh at home.
Old 06-20-2007, 04:13 PM   #1387
MrBlack's Avatar
Somebody is because they make way more money than the RC industry does.
Old 06-20-2007, 04:15 PM   #1388
sportpak's Avatar
What a shame..
Old 06-20-2007, 04:18 PM   #1389
MrBlack's Avatar
Yes it is.
Old 06-20-2007, 06:14 PM   #1390
That's where I would start.
Well, My LHS did that. I'm told that Orion didn't know what to do, if they are responsible or the battery manufacture.
knapster is offline   Reply With Quote
Old 06-20-2007, 06:18 PM   #1391
chris72983's Avatar
What might that be? And how long?
Old 06-20-2007, 06:49 PM   #1392
yyhayyim's Avatar
If its a heavier pack, then the power/punch of the pack will probably need to be inproved so that it feels like the power of the 3200 or 4800 lipos?
yyhayyim is offline   Reply With Quote
Old 06-20-2007, 07:06 PM   #1393
SWTour's Avatar
I thought about a lipo testing scheme for some time. If not high constant current load; how about measuring transient response to varying loads? I'm almost certain that if we use impulsive loads and moderate constant current loads in a repetitive pattern it will work. Then graph or create formulas to translate the results to usable data for grading cells. You can also change the load patterns to grade cells for different classes of racing. I can probably build this machine and write the software for it but not out of my pocket! hint hint Mr. Black!
I've thought about something crude in this fashion using some type of pulsing relay (or something like a Heavy Duty Automotive Flasher unit), hook the battery up to something that would pull a constant 15 amps discharge, and have the pulsing relay kick in an additional 25-30 amps for 1-2 seconds at a time, and do this over a timed run period too.
SWTour is offline   Reply With Quote
Old 06-20-2007, 08:53 PM   #1394
Send a message via AIM to 4wd Racer
Honestly my speculation is that the next Lipo from Orion/Peak isn’t necessarily that much heavier. I imagine it would weight more than the current 3200/4800 Lipo being offered, but at a closer weight but however at the same time less than today’s 14.1 oz of 4200 NiMh. I think that the new Lipo’s weight will be under that, but Orion will build a feature into the Lipo pack that would allow the user to vary the overall weight of the pack as desired by allowing them to add/remove weights incorporated into the sides of the pack! How’s that for creative thinking and marketing if that were to ever happen?
The truth is I really don’t want the next Lipo to be 14.1 oz like the current NiMh. I really hope not, and if they are I probably will stick with the current 4800 Lipo which is more than enough for 2wd/4wd off-road mod racing. Just adding some oz. of weight to the current 4800 Lipo to make it less than 14.1 oz is perfectly fine, say 12-13 oz. for instance. In fact I personally think the current 14.1 oz NiMh weight is too heavy, slows the responsiveness of your car down, and makes both of your cars prone to breakage when landing off jumps, clipping a pipe, or whatever. I liked it when we were running the lighter GP-3300, and even better with the NiCd 2400 & 2000.
The thing is its not like you have to make the pack to meet the 14.1 oz weight to comply with ROAR guidelines for weight, or for club racing! This is furthest from the case and a misconception among some racers who think that the next Lipo should be 14.1 oz to make it fair, or level the field out competition wise. I think that shouldn’t be the case!
For instance if my memory serves me right ROAR states the weight class for the 2wd to be 52 oz & up, and 4wd to be 56 oz & up. Those are my favorite class to run. The truck is 60 oz & up I believe. The current crop of 14.1 oz NiMh are porkers and heavy, especially with newer ones coming out with larger capacity, and put our 2wd & 4wd well over their respective minimum weight of 52 oz, and 56 oz, and way to heavy in my opinion.
I’m not sure exactly what the next Lipo’s weight should be to at least make our car heavier and lighter at the same time, and at least meet weight. This would be an interesting subject to research at least. For starters the 4800 Lipo is 9.1 oz, but in reality it isn’t really that too hard to get creative and add flat super thin lead weight low to the chassis on the sides of the battery channels (for the lowest center of gravity imaginable possible!) to at least meet each class respective weight if you shop around at sports store or online retailers. It’s very doable!
It would be nice if somebody with a accurate weight scale would weight a NiCd 1700/2000/2400, and all the way up to the NiMh 3000/3300/3800/4200 to get at least a baseline weight reading of how our packs got heavier over time. I personally think a lot would be surprised at the changes of the overall oz. on each pack! I will check around here to see if I can do that for the time being.
A “variable” weighted Lipo pack that you can change the overall oz. weight at the user’s preference would be awesome, and I hope that is the case! Does anyone have any thoughts or comments on this?
4wd Racer is offline   Reply With Quote
Old 06-20-2007, 08:57 PM   #1395
Thats all well and good as long as everyone runs off road.
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
