Team Orion 3200mAh Race Spec LiPo >
Old 06-04-2007, 10:57 AM
  #1336
secretsg's Avatar
Are the cases available separate from Orion? I want to hack up a case for a saddle pack.
secretsg is offline
Old 06-04-2007, 11:10 AM
  #1337
MrBlack's Avatar
As of right now the cases are not available separate.
MrBlack is offline
Old 06-04-2007, 11:44 AM
  #1338
Trader Rating: 38 (100%+)
Originally Posted by Leodis View Post
Why would you set max capacity at 50%? I've been charging at 1C and would like this explained and verified before I start charging at 2C.
If you double the mah setting to get to the charge rate you want then you need to half the max charge so you dont overcharge it. It works for me and others but MrBlack cautions against it.
or8ital is offline
Old 06-04-2007, 12:34 PM
  #1339
chris72983's Avatar
My charger has a max charge rate of 2.5 will it hurt the battery to be charged at that? I heard that you wasnt supposed to charge it below some amount also, But I dont recall what it was.
chris72983 is offline
Old 06-04-2007, 12:40 PM
  #1340
Is there any advantage to charging the 3200 at 2C, other than a reduced charge time?
chance is offline
Old 06-04-2007, 12:42 PM
  #1341
MrBlack's Avatar
This depends on the charger some that charge at this rate will also not charge a battery fully beyond 2500mAh but their are some that will do it no problem but it will just take longer to charge.
I would contact the charger manufacture to get their opinion.
MrBlack is offline
Old 06-04-2007, 12:44 PM
  #1342
Nope.
or8ital is offline
Old 06-04-2007, 12:45 PM
  #1343
MrBlack's Avatar
Originally Posted by or8ital View Post
Nope.
He is correct. You can even go back and forth between 1C and 2C without any ill effect.
MrBlack is offline
Old 06-04-2007, 03:04 PM
  #1344
hey guys.
apart from being light weight do lipo have a voltage advantage over a good ib4200 pack? my local track wont allow lipo in stock or 540 cause they think it will be unfair im trying to convince them that lipo are a cheaper alternative and that they should allow them.
i saw some test showing discharge curves of lipo versus nimh any one know where on is or if i have got my facts wrong?
cheers
aus jd 2703 is offline
Old 06-05-2007, 10:11 AM
  #1345
MrBlack's Avatar
Originally Posted by aus jd 2703 View Post
hey guys.
cheers
Well some people will say that a good 4200 will be an advantage over a LiPo.
2 cell LiPo tops out at 8.4V
6 cell NiMH tops out at 9.6V+
Charge one of each style and show your Track Official the volktage when fully charged this should remove any concern about un fair advantage.
The Discharge curve on a LiPo is much flatter then a NiMH so this is were any advantage comes into play. But then you can argue well LiPo is at a 1000mAh disadvantage.
MrBlack is offline
Old 06-05-2007, 10:31 AM
  #1346
chris72983's Avatar
I called thunder power today and they said the charger cut off by voltage not mAh, and the it would be fine to charge a 3200mAh batt. at 2.5 amps on it. Does this sound right to you.
Old 06-05-2007, 10:35 AM
  #1347
Regional Moderator
Darkseid's Avatar
hey guys.
cheers
The only on track advantage is the weight. Often times people who try the LiPo for the first time swear its "faster" or "punchier", and they attribute this to extra voltage. In reality, its much simpler than that...if the car is carrying less weight, it will take off faster.
So if they want to maintain "fairness" (if there is a such thing in R/C), then just have a weight limit. That way, the LiPo and NiMH runners will all have to weigh in at the same thing and all the advantage of lighter weight is removed.
If they still wont allow you to run it, ask them how "fair" it is that some guys have $80 packs with insane numbers while others can only affoard budget packs with crappy numbers. If they still have a problem with you running it, I say find somewhere else to race.
Darkseid is offline
Old 06-05-2007, 10:37 AM
  #1348
MrBlack's Avatar
Yes this sounds correct and you should be fine.
MrBlack is offline
Old 06-05-2007, 10:38 AM
  #1349
Regional Moderator
Darkseid's Avatar
Its funny to me that nobody seemed to give a flying fart about "fairness" in the battery department until LiPo came along. I mean, does anybody ever remember tracks making sure that an entire class' batteries had the same numbers? No...
Now all of a sudden, track owners are SOooooOoOooo concerned about fairness. I guess since the issue of safety has pretty much be settled, people have to have something to complain about with LiPo.
Darkseid is offline
Old 06-05-2007, 10:49 AM
  #1350
I got spanked last week by a guy using a brushed motor and nimh batteries. How unfair!
or8ital is offline
