Team Orion 3200mAh Race Spec LiPo >
Old 05-31-2007, 08:11 PM
  #1321
slakr's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Darkseid
THe ICE and these packs are a perfect fit. You put the settings in correctly, and theres pretty much no chance of "frying a pack". I've been using my ICE with my Orion 4800 for about 2 years now, and its never had a problem
I have an ICE and just picked up an Orion 3200.
What exactly are "correct settings"
Went brushless this winter and now LiPo, so I am kind of green on how to properly charge my new pack.
Thanks.
slakr is offline
Old 05-31-2007, 09:24 PM
  #1322
Regional Moderator
Darkseid's Avatar
Thanks.
For the 3200, it will be:
Set the pack type- LiPo
Set the voltage- 7.4v
Set the Capacity- 3200mah
And then the charger should automatically adjust to the max charge rate that the ICE will allow for a 7.4v 3200mah pack. Its that simple.
Darkseid is offline
Old 06-01-2007, 08:09 AM
  #1323
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
Is it true we can now charge our 4800 lipos at 2C rate? If so, on the ICE charger, do we set the mah to 9600 so it can charge it 9.6V?
yyhayyim is offline
Old 06-01-2007, 08:28 AM
  #1324
Trader Rating: 38 (100%+)
and max capacity at 50%
or8ital is offline
Old 06-01-2007, 08:55 AM
  #1325
MrBlack's Avatar
A charger that is designed to charge at 2C is recommended IE. a charger where the capacity and Amperage can be adjusted individually.
To 2C charge the 3200's you should charge the battery at no more then 6.4A and maintain the 3200mAh capacity.
If your charger does not do this then it is not recommended you try and "trick" your charger as this often bypasses some of the dsafety features and you easily damage your cells.
MrBlack is offline
Old 06-01-2007, 09:00 PM
  #1326
SWTour's Avatar
Mr. Black,
Would my Orion Advantage charger be one of those that will work...or would it be one that would be being fooled?
TIA
SWTour is offline
Old 06-01-2007, 09:46 PM
  #1327
ottoman's Avatar
or how about my Advanced flight charger? I admit I have been charging my 3200 at 5 amps with it
ottoman is offline
Old 06-01-2007, 11:15 PM
  #1328
Trader Rating: 26 (96%+)
Does the 4800 and 3200 have the same cells? I am wondering if there would be any issues if I wired up the two in parallel to make a 20 minute main.
party_wagon is offline
Old 06-02-2007, 05:31 AM
  #1329
kuzo's Avatar
I don't know all the differences but the 4800 uses 15C cells and the 3200 uses 20C cells. Whether that would cause any problems, I don't know but I personally wouldn't mess with it.
kuzo is offline
Old 06-02-2007, 03:31 PM
  #1330
slakr's Avatar
Took a look at my new Orion 3200 today (waiting for my Orion charger to arrive on Monday to charge it) and I noticed something that struck me as odd...
The +, - and balance labeling on the battery sticker was at the oposite end of where the jacks are physically. I began to think and concluded that if the sticker was applied backwards, that would mean that the + and - jacks were incorrectly labled. So, I had to get out my meter and check for proper polarity.
Then I carefully peeled off the sticker and applied it to the battery the right way.
slakr is offline
Old 06-02-2007, 05:20 PM
  #1331
If you look real close you can see the + and - molded into the pack at the terminals.
blshar is offline
Old 06-03-2007, 06:22 AM
  #1332
Any word on a "heavy" case lipo?
or8ital is offline
Old 06-04-2007, 10:29 AM
  #1333
MrBlack's Avatar
Where the positive and negative on the decal on the opposite side of the ports?
Final details are being worked out as we may be up the anti a bit.
No they are not the same cells and I would not wire a 3200 to a 4800 in parrallel however 2 3200 or 2 4800 will work in parrallel.
MrBlack is offline
Old 06-04-2007, 10:32 AM
  #1334
MrBlack's Avatar
Originally Posted by SWTour View Post
Mr. Black,
TIA
Yes the Advantage Advanced Charger will sharge cells up to 10A regardless of cell count.
The flight is designed to charge at 1C anything further and you are risking damaging your equipment.
MrBlack is offline
Old 06-04-2007, 10:34 AM
  #1335
Leodis's Avatar
Trader Rating: 16 (100%+)
Why would you set max capacity at 50%? I've been charging at 1C and would like this explained and verified before I start charging at 2C.
Leodis is offline
