Team Orion 3200mAh Race Spec LiPo
#1276
A buddy of mine tried to order a 3200 from his LHS and they told him that it was discontinued.
Is this true?
Or does this have something to do with redsigning the pack to be heavier to help meet minimum weight requirements?
Also, does anyone know how difficult it would be to fit the 4800 into the T2R?
Is this true?
#1277
Is this true?
Is this true?
They are not only still in production but they are in stock. There is a certain distributor [who shall remain nameless] that displays "discountinued" on their site once they are out of stock on certain products. Sorry your friend was mis-informed. You can even go to www.shoppeakracing.com to order them direct from Peak if your LHS is un-willing to carry them.
#1278
i just got my 3200 packs today with my orion charger
and i like them
and i like them
#1279
and i like them
and i like them
#1280
Is buying a discrete cutoff circuit like the Novak units the best way to use lipo's with speed controller's not having voltage cutoff? I'd like to use two 3200's in series to power a 700 size motor in boat with a Jeti 600 navy speed controller.
#1281
#1282
Originally Posted by MrBlack
If you are running two batteries in series then yes I would suggest running a voltage cut-off.
#1284
Do you have a system you recommend?
#1285
MrBlack - That's why I like this one Apogee LOA. It's alarm goes off after it has been connected for more than 60 minutes. You can't mistake the sound when it goes off either.
#1286
The SWTour Oval Series will be at the ENCINO VELODROME in Southern Calif. this weekend, and we'll be trying our first 4300B/L class using the 3200 LIPOs mixed in w/ our 4 cell OPEN MOD class.
We are expecting at least 5 cars to try the lipos, and expect them to be somewhere between 62-65 mph.
FYI - for those that don't know what a VELODROME is. Velodrome = HIGH BANKED Concrete oval bicycle track. This one is 264 meters (Or about 960 ft. run line)
Joe Myers
South-West Tour "R/C Oval Series"
Official 'TOUR' Sponsors
FINISHLINE R/C Products
T.M. Racing Tires
Jake's Performance Hobbies
Maverick Oval Chassis
BSR Racing Tires
McAllister Racing Bodies
STICK E.T. Tire Sauces
WWW.SOUTHWESTTOUR.COM
Joe Myers
T.M. Racing Tires
BSR Racing Tires
#1287
#1288
My thought is that features like added weight should be an add on to the pack. Have it snap onto the bottom or top of the plastic pack. Do the bumps on the bottom of the 3200 really lower its CofG (ie, the lipo cells actually have that shape), or is it simply a way to help retain them on notched chassis? If the chassis is flat bottomed, like a Losi MF2 stadium truck, they (simulated cell shape) do neither good nor harm.
#1289
The bumps are simply there to lock the battery in and they are not filled with cell material. the round shape is necessary to comform to stick pack applications which are still the dominant need amongst the general customer base and we chose to take advantage of this and put in the bumps. Actually the original 4800 case was the case used for the 3200 however the cells in the 4800 required more room so we went with the brick shape.
