Old 04-25-2007, 01:47 PM   #1216
Now I am no electrician, but there are 3 cells in the 3200, but I suspect I need the 2-cell smart stop right?
There are 2 cells in the 3200 (3.7v per cell). That should answer your question about the smart step.
Steve B is offline   Reply With Quote
Old 04-25-2007, 02:02 PM   #1217
According to the information on Tower for the 3200 Orion Pack:
"Number of Cells: 3 cells in a 2S1P configuration (2 cells series and 1 cell parallel)"
Therefore my question.
CaliberX is offline   Reply With Quote
Old 04-25-2007, 02:52 PM   #1218
TEM
TEM's Avatar
2S1P means there are 2 cells and not 3.
3S1P means 3 cells in series.
2S2P would mean 2 series sets of 2 cells in parallel meaning 4 cells total
TEM is offline   Reply With Quote
Old 04-25-2007, 03:19 PM   #1219
syndr0me's Avatar
Trader Rating: 32 (100%+)
Is there any reason this charger couldn't be used to both charge and balance Orion's batteries? Would you just need to wire up the 2P harness like the previous pictures we've seen to make it work?
http://www.precisionrc.com/nv/car/pr...=news_Estation
It appears to be the size of the charger many of us are already using, with the ability to balance charge as well.
syndr0me is offline   Reply With Quote
Old 04-25-2007, 03:41 PM   #1220
MrBlack's Avatar
TEM is correct, 2S1P means two in Series one in Parallel, correct
S= in Series P = Parallel
Our 4800 is 2S2P you set the charger and discharger based on the S so any thing with 2S would charge and balance as a 2 cell. You go by the S rating to set the charge rate if you where to try and charge the 4800 as a four cell you would damage it.
3S would be treated as a 3 cell.
To simplify it think of 2 cells in Parallel (2P) as two haves of ONE cell.
The P is not a factor in desiding the cell count when it comes to charging or balancing.
1S = 3.7volts, 1 cells
2S = 7.4volts, 2 cells
3S = 11.1volts, 3 cells
4S = 14.8volts, 4 cells
etc, etc.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 04-25-2007, 03:57 PM   #1221
MrBlack's Avatar
This is a miss print and we are taking steps to have them correct this as you read this.
It should read "2 cells in a single parallel configurations".
Old 04-25-2007, 05:39 PM   #1222
Thanks for the clarification Mr. Black - I figured, but the Tower description threw me off.
Old 04-25-2007, 08:43 PM   #1223
TEM
TEM's Avatar
I think tower had the weight wrong too..
Old 04-28-2007, 11:25 PM   #1224
Well, I finally have a 3200 lipo coming, about time i say. Using it for drifting only, and it sucks, i cant even use it in an official drift comp, but there's dicussions about allowing them.
Running on ABS with a mamba 4600 & an 8.53 ratio, how much runtime do you think i would get out of it?
Also, with the mamba it has an auto cut-off for lipo, but im a bit skeptical about using it, and ill still be using nimh cells aswell. Has anyone used this lipo with there mamba & auto cut-off?
cairnsrc.com
REC'd Racing
What I have - Brushless Slash 4600kv, DX2S
What I need - Boss Motorsports 10.5, TRC LCG chassis, Ford F-150 SC body, Proline Protrac & a Brushless XXX-T CR MMP4600kv. Not alot!
Drift Demon is offline   Reply With Quote
Old 05-02-2007, 04:34 PM   #1225
sportpak's Avatar
Trader Rating: 26 (100%+)
Does anybody know where I can get a Orion Avionics Advanced Flight Charger?? They've been on backorder for flippin' ever. I'm kicking myself for not getting one when I had the chance. Any ideas?
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 05-02-2007, 04:45 PM   #1226
Rick Hohwart's Avatar
You're in luck, we just received a shipment that will be heading to distributors/dealers beginning tomorrow. Our website is down, otherwise that info would have been posted.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 05-02-2007, 06:16 PM   #1227
flying G.E.O.'s Avatar
Originally Posted by MrBlack
So far our intitial testing has not shown any problems with placing it at 110% however this has only been done a couple of cycles. So the full test is yet to be complete. Setting it to 90% fully charges the cells and is the recommended setting until further notice.
So any update on the testing? My ICE was set at 100% but I have less than 30 cycles on my platinum and less than 15 on my carbon. What's the effect of having it 100%? I didn't see it go over 8.45v.
www.3dgallery.co.nr
flying G.E.O. is offline   Reply With Quote
Old 05-02-2007, 06:46 PM   #1228
wallyedmonds's Avatar
ill just have to figure out how to charge them when i get them and read the book that comes with the orion charger.
and to charge the 3200's right.
im lost with lipo's
or can someone say in a simple way with 3200 orion pack how to charge with an orion charger.
wallyedmonds is offline   Reply With Quote
Old 05-02-2007, 06:59 PM   #1229
syndr0me's Avatar
im lost with lipo's
There's 3 options, battery type, capacity and voltage.
LiPo, 3200mAH, 7.4V -> charge. With the advanced flight charger, that's all there is to it. It shouldn't go any higher than 3.2A when it's charging, and will steadily drop the charge rate until it's finished. When you hear it beep, it'll usually say "end" which means you're done.
Old 05-02-2007, 07:34 PM   #1230
oh i should have said the advantage carbon charger or do they do the same when charging lipos.
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
