Team Orion 3200mAh Race Spec LiPo
#1156
Found this,
The Triton Jr has the same specs, but the board is a different design.
http://www.rcgroups.com/forums/showthread.php?t=563981
#1158
Originally Posted by rays_tt
Thanks for that, because I run a novak 5800 with a GTB and 2cell smart stop, I just stop running once the blue LED goes on, is there anything else I can do to stop it from going below 80% as the smart stop cuts off at 6.??V
Also if I dont ever charge it to its full capacity (3200) how would I check that it has been fully charged if I say start charging them at 30% capacity, 40% capacity etc? by reading the voltage?
Oh and I was also considering getting the Avionics charger, but instead got the ICE, the avionics would of costed me roughly 125, and for $25 extra I got the ICE instead, you guys reckon that was a better move?
Thanks.
Thanks.
Your charger should do constant current until it reaches 8.40V for a 2 cell pack. Then it switches over to constant voltage and holds voltage at 8.40V while reducing the current. Once the current drops to 1/20C, then then charge is usually stopped. When the charger switches from Constant Current to Constant Voltage, the battery is already 90-95% charged.
#1159
Ahh ok thanks. So I can just charge my Lipo pretty much after I run it for even 5mins if I wanted to?
Because I think someone said its bad to top off your Lipo, but I think he doesnt know what hes on about.
#1160
In all fairness if you want to stay ahead of the future, buy a charger that will charge at 10 amps.
The future of lipos will more than likely grow and as it does the MAh's will to and you will need a charger that will charge them at a higher rate.
So as the times change. So will chargers.
Even my ICE will be obsolete some day and it charges at 4.8 amps.
That is for lipos the highest I can charge is 4.8 amps.
#1164
So the ICE only charges lipo's to 4.8A MAX ?
I'm charging platinum 4800's right now so I should be set for a while.
But I plan to jump into some higher MAH's this next winter.
The higher MAH's are over rated if your running stock.
You only need the higher MAH's to make run time with hotter motors.
It will charge at higher rates on sub-c.
Lots of advantages to the higher MAH's. When it comes to longevity.
You will be able to run 20% of the packs charge in a five minute race.
Unless they start running 10 minute mains with the packs of the future you will be able to make them last forever.
(If you use the charge and repeak with out running more than 1 round at a time before repeaking them.) Its the best method of use for lipos.
I will double check the charge rate on my ICE for Lipos.
#1167
scaring me man, I was thinking I'm sure the ICE can go pass 4.8A
I'm glad I checked it.
Bring on the 6000's now.
All this talk of chargers today got me thinking and looking at the future as far as lipos are concerned. And what charger would I really recommend in order to stay ahead of the game.
#1168
Eventually we will be charging at higher and higher currents but I think I will get my moneys worth out of my ICE long before that happens! Even if the capacities we need don't increase by 3 folds (we don't need 10amp cells for racing anytime soon, flying maybe... ) I can see cells that take a higher charge rate in the very near future so higher charge rate is definately a bonus. But still, the same cells will charge just FINE on lower C. No need to worry!
#1169
I have 2 packs and repeak each one in between rounds and it works out great.
That is as long as its not discharged more than a round at a time.
