Old 04-10-2007, 03:49 PM   #1111
MrBlack's Avatar
Originally Posted by TEM
Comes out to 138.50mm! The casing looks a bit "loose" like there is a small gap I can pinch out but I'm not concerned, yet....
Anyhow; it just didn't fit into the chassis and it's not a spot where you can carve and sand to make fit....
Even at 138.5 it should fit? A 6 cell side by side pack is even longer then that width and they fit as well.
I wonder of your chassis warped a little bit during the cooling process?
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 04-10-2007, 04:00 PM   #1112
TEM
TEM's Avatar
I have 2 of these chassis and it dont fit in either one. Actually 3300 side by side is the bigest that will fit on this tub chassis. Even IB's don't fit. I use it for TCS cause it's legal for GT2 in Canada and we run Peak/Orion Powermaxx stick packs in GT2.
I have a 4800PE and it fits (got my hopes up!) so I figured the 3200lipo would fit and I bought it so I can use it in GT1 which now allows 3200lipo. The TA04 has the cells running sideways so it's balanced side to side and I don't need to add weight. I guess thats they way it's gonna be; unless there are different batches of 3200's and I might come across one thats smaller and fits?
TEM is offline   Reply With Quote
Old 04-11-2007, 12:19 AM   #1113
linger's Avatar
I can't believe you guys made me dig out my old TA04.
The 4800 Orion lipo is a press fit. TEM is right. Another 0.5mm and it would not fit. If the 3200 case is any bigger, then I suggest - (MR. Black - don't read any further) - a belt sander to the battery case. Just take off a measly 0.25mm per side. Don;t worry, the case is thick enough were 0.25 mm removed won't do any harm.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 04-11-2007, 07:32 AM   #1114
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Actually it's the GT1 class that's allowing the 3200 Lipos in Canada, we're still stuck with 2400 Maxx Packs for GT2.. wish we were using Lipo, I'd rather buy one 3200 than having to buy 4 of those NiCD packs.. better performance and cheaper..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 04-11-2007, 03:09 PM   #1115
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
where can i get a plug to fit in the balance hole? It was easy to find reg euro plugs for the + and - but I have no idea what size or type the balance port is.
thanks
floodo1 is offline   Reply With Quote
Old 04-11-2007, 03:29 PM   #1116
Rick Hohwart's Avatar
thanks
The required plug is 2mm found here #62503.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 04-11-2007, 04:28 PM   #1117
SWTour's Avatar
Mr Hohwart,
I know you have much bigger fish to fry than OVAL racing, but I'd love to be able to talk with you about getting involved w/ our small oval program and helping introduce these guys to the Kokam sealed Lipo batteries from Peak/Orion.
We've been doing testing on different Brushless/Lipo combinations and we've got people watching and listening all over the country in both Oval and On-Road Racing.
We are also working in conjunction w/ J.B. from ARCOR on finding a limited Brushless motor to couple with the 3200 Carbon Edition batteries as a replacement for our 4 cell STOCK class. The motors we're testing so far not only look like an awesome direction for this replacement class, but also for a entry level brushless touring class motor as well.
If interested, please contact me so we might talk
Joe Myers
South-West Tour R/C Oval Series
www.southwesttour.com
[email protected]
SWTour is offline   Reply With Quote
Old 04-11-2007, 05:05 PM   #1118
TEM
TEM's Avatar
I ended up putting on the flat carbon graphite chassis and the 3200 now fits but TIGHT. If I get T-boned I bet the battery mounts will break off cause it's so tight at the ends. I'm considering running one side only and using tape to keep the pack from moving.
I charged the new 3200 for the first time. My ice charger put in 13XXmah to top it off. With the same EVERYTHING except for battery and chassis. I tested it on my driveway and it seems decent in terms of power. No real data until I get to go to the track. The added bonus is I won't have to add any weight cause L/R balance remains. However, the reduced weight means I need a wack of time to set it up to drive right.
Old 04-11-2007, 07:03 PM   #1119
Iceracer's Avatar
Tried an Orion 3200 out for the first time tonight. I got about 20 minutes runtime at pretty much full throttle with a Novak 13.5 brushless motor powering a XXX-T. The cutout on the Sphere esc seems to work properly in the lipo setting. I can definately gear up as the motor was barely warm. On the other hand it is only 6 degrees C out. I'd imagine it will draw more amperage when I go up in pinion size.
Iceracer is offline   Reply With Quote
Old 04-11-2007, 07:55 PM   #1120
SWTour's Avatar
Burrrrrrrrrrrrrrrrrr
Old 04-12-2007, 06:25 PM   #1121
jhigga15's Avatar
does that fit well in the Tamiya Evo cars?
Thinking of fixing my Evo 4 and getting one of these...
jhigga15 is offline   Reply With Quote
Old 04-14-2007, 11:58 AM   #1122
Default Balancing/Equalizing Port
This may have been discussed here already, but there are so many posts to go through.
How do you use the balancing port on the carbon 3200 battery? I have a hyperion LBA10 balancer and on the battery, there is no extra wire ports for the balancing plug.
[RC10TC] is offline   Reply With Quote
Old 04-14-2007, 12:38 PM   #1123
Iceracer's Avatar
The single small connector in the centre is the connection between the two cells. You might have to make up a custom harness to plug your balancer into it. You've got the three connections that make up 2 cells in series, +, middle (-/+), -
Old 04-14-2007, 04:14 PM   #1124
Default What I meant is...
What I meant is...other lipo packs (max amps, apogee) have two sets of wires coming from the battery. One for balancing and one for charging/esc. On the carbon 3200, there is only the three ports (positive - balance port - negative) Does anyone know how to wire it so it can be used with a Hyperion LBA10 balancer?
Old 04-14-2007, 04:52 PM   #1125
Nexus Racing's Avatar
hooking up a balancer:
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
