Team Orion 3200mAh Race Spec LiPo
#1021
What kind of male connector goes into the Orion packs? Standard corally?
Any idea if its a 3.5mm or 4.0 mm male plug?
#1022
Hows the 3200's with 19T Touring? How many mah from the charger(what model too for reference) are you putting in after a race? (no I would NOT ask that question for nimh).
For the guys adding weight to a 3200; would it make more sense to run the 4800PE if it was legal for your class?.. It's got more weight!
#1023
#1024
Originally Posted by syndr0me
If it fits, and it's legal, it does indeed have more weight. It's hard to add much weight to it, though, because it's a brick. I have found it easier to add weight to the carbon edition.
i was able to add 14 grams between each of the little feet (so it was lower CG and sat even more secure in between the battery slots) and the rest of the weight up top.
if i dont forget, i add up the weight so you guys know and take pictures tonight.
#1025
I made the balancer lead exactly as described in this thread, but my Equinox only recognizes one cell. I double checked my construction as per instructions earlier in this thread, and it is correct. The cells measure 4.16 volts each with dvom, but Equinox only reads it as one cell with all leads attached. If you remove any one of the 3 leads, the equinox does not recognize it at all. Anyone else had this problem? I'll try it on the Astro Blinky and see what happens.
#1027
Hi guys, dont have a balancer so can I just charge each cell individually at Max1.6A and 3.7V?
#1028
The individual cells have 3200 capacity so you can charge them at 3.2A
#1029
Weight wise I have added 120g to balance the car (we dont have a weight limit at the club), 60g to the chassis and 60 on top of th carbon.
#1031
Originally Posted by bukil
Where do you guys buy your lead strips/tapes?
#1033
Originally Posted by c1 racin
Found another great deal on the Orion 3200 Carbon for $72.49 at Nexus Racing! With a price like that, everyone should be racing LiPo's!
I just checked nexusracing and the price is now $81.99 and not $72.49 as stated above. Does anyone know where i could get these cheaper? Speedtech is the cheapest ive found at $79.99. thanks in advance
#1034
Do you know any online stores that sells them?
http://www.microtechracing.com//prod...NG+ACCESSORIES
#1035
