Team Orion 3200mAh Race Spec LiPo >
Old 03-15-2007, 07:27 AM
  #931
Iceracer's Avatar
Any opinions on the Integy Indi 16x307 charger?
http://www2.towerhobbies.com/cgi-bin...p?&I=LXPPD3&P=
At $54.00 it looks like a real bargain, charging at up to 6.5 amp rate.
Iceracer is offline
Old 03-15-2007, 07:50 AM
  #932
I like the 6.5 amp available charge rate, and the fact that you can choose to charge only to 4.15...if cycles are more important to you than full power. However, I'm concerned it could be too easy to bump the amp wheel and fry a battery. Also, it doesn't have any built in balancing. You could use an external balancer, but that costs more, and depending on the balancer, you'd lose the option of the 4.15 peak (some balancers only balance when cells hit close to the 4.2v rate....some do continuous balancing during the charge cycle.)
In general I think this could be called a "stupid" charger...and that can allow you to be stupid and ruin a battery. All this charger does is charge at constant amperage based on the settings you chose (cell count, amp rate.) It doesn' attempt to determine the true cell count or battery size. In comparison the CellPro automatically calculates the cell count and automatically determines the battery capacity and then automatically sets the charge rate based on the 1C rule. The CellPro is idiot proof and I've been known to be an idiot now and again.
Disaster is offline
Old 03-15-2007, 08:07 AM
  #933
Iceracer's Avatar
Good points Disaster.
How does auto current sensing work? How does the charger know you've plugged it into a 700mah or a 4800mah lipo cell?
Iceracer is offline
Old 03-15-2007, 08:19 AM
  #934
That is a good question.
When I watch the Cellpro display during startup it will slowly increase the charge rate, then decrease it back slightly and hold it at that level. I'm guessing it is some sort of logic, similar to delta peak based on the voltage that must be applied to get the constant current. After a minute or two of this feedback it determines what the capacity must be and then it gives you a percentage charged. Lipos charge/discharge rate is affected by temperature and it has a built in thermistor which it probably uses to improve the accuracy (as well as protecting against overcharging in cold climate.)
Unfortunately the Cellpro is limited to 3 amps....which is good enough for my current batteries...barely. Hope they come out with a more powerful model in the next year or so.
Disaster is offline
Old 03-15-2007, 11:32 AM
  #935
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
What is CellPro? Any link? Also, any good balancer you guys recommend?
Mike Schumacher is offline
Old 03-15-2007, 11:35 AM
  #936
MrBlack's Avatar
Originally Posted by sim600
MrBlack,
Glad you are on here. In the instructions that came with the 3200 Carbon LiPo, it says to charge it between 2amps and 3.2amps. What happens if we charge it at under 2amps with a LiPo charger? Thanks.
THis depends on the charger many chargers that top out at 1.5Amps have shown to not fully charger the battery also those that do take upwards of 2 hours to chrge the cell properly and having a charger running hard for 2 hours straight can prematurely burn up the charger.
MrBlack is offline
Old 03-15-2007, 11:56 AM
  #937
Here is a link to the CellPro. It is a great charger up to about 3000-3500mAh batteries. If you charge a 4400mAh battery with it, it will take about an hour and a half to charge vs. 1 hour, 4 minutes, for the 3200mAh battery. It won't hurt the charger according to FMA Direct...just take longer.
The Cellpro automatically balances as it charges so you don't need a separate balancer. You will need to buy or make an adapter, depending on what brand of Lipo you have.
http://www.fmadirect.com/products.htm?cat=45&nid=4
Disaster is offline
Old 03-16-2007, 07:49 AM
  #938
MrBlack's Avatar
Originally Posted by linger
Hopefully, Cliff will be able to share results of 2C charging of cells greater than 2000mAh.
I have just gotten the graph this morning from Kokam, here is a chart showing the 3.2A (3200) cells being tested at 2C charge rates:
MrBlack is offline
Old 03-16-2007, 08:01 AM
  #939
Trader Rating: 38 (100%+)
So Im confused. This suggests that charging at 2C doesnt rapidly deteriorate the cells (contrary to lingers chart)?? Can someone interpret for me?
or8ital is offline
Old 03-16-2007, 08:12 AM
  #940
Wow, that is pretty incredible performance...especially compared to Linger's results. Is that a new technology or the stuff they are already using?
Disaster is offline
Old 03-16-2007, 08:15 AM
  #941
Iceracer's Avatar
Mr Black, how does that compare to 1C charge over the same # of cycles?
Iceracer is offline
Old 03-16-2007, 10:11 AM
  #942
linger's Avatar
It just means that the larger kokam cells are a lot more resistant to higher charge rates compared to the smaller kokam cells. Thanks for the info Cliff.
linger is offline
Old 03-16-2007, 10:37 AM
  #943
MrBlack's Avatar
1C is still better but not by as much as you would think.
MrBlack is offline
Old 03-16-2007, 10:39 AM
  #944
MrBlack's Avatar
Ling is correct the larger cells have the ability to take more abuse then the smaller cells due to increased capacity.
This is one of the reasons why we try and use fewer larger cells then assemblies that use several smaller cells such as those found in laptop batteries which do not require the amp draw that our cars do.
MrBlack is offline
Old 03-16-2007, 10:45 AM
  #945
So in the experts opinions am I ok to charge at 2c (6.4A)?
or8ital is offline
