Old 03-07-2007, 09:45 AM   #826
MrBlack's Avatar
Originally Posted by Iceracer
Their 3200's but they are really 40% more than tat. Makes me think of "This is Spinal Tap", and our amps go to 11.
Why don't they just call it a 4480 if its 40% more capacity than a 3200?
If we called it a 4480Mah we would be lying.
Capacity is a measurement done before pack assembly. LiPo's lose far less to resistance after assembly and cycling.
Plus the batteries are capacity rated for a different application then we use.
It's like a hamburger, a quarter pounder is only such before cooking.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 03-07-2007, 10:13 AM   #827
Iceracer's Avatar
Ok, now this sounds like the best thing since flush toilets and electricity, and I'm sure even those had their critics.
Originally Posted by MrBlack
I run mine every Sat. and I cahrge them usually on Wednesday and then run on Sat. It takes more then a week before you see any noticable discharge and even then it is so minor that it's more like 2-3 weeks before you caould even tell out on the track.
We have batteries that have have a sat on a shelf for a year and have only lost 10-15% of their charge.
Iceracer is offline   Reply With Quote
Old 03-07-2007, 10:15 AM   #828
Okay thanks! Just to be clear, if it has been 1-2 weeks I can repeak them and it won't hurt the battery at all, just might not be much benefit?
speedythecat is offline   Reply With Quote
Old 03-07-2007, 10:23 AM   #829
Tech Legend
Wild Cherry's Avatar
Go ahead , repeak ...
When you do, the charger will know the pack has a charge and you will only see the charger recharging the pack at less than .5 amps for just a short time ....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 03-07-2007, 11:01 AM   #830
Rainey's Avatar
Being that I am new to the Lipo deal but have been using Nimh batteries for a while, all of this info is vey helpful. I will be purchasing some Lipos in the very near future since we allow them in our racing series. (see sig) I do have one question though. After reading all of the info someone posted about the diff between "top tier" and China products, I was wondering why the price diff between the Peakand Orion batteries. They look to be the same and i even noticed that Mr Black has both companies listed in his sig. My understanding is that these companies are the same, so to speak.
www.rcracingxtreme.com
racers running races for racers !
Rainey is offline   Reply With Quote
Old 03-07-2007, 11:02 AM   #831
Oh Okay, even with my Multiplex LN-5014?
Old 03-07-2007, 11:04 AM   #832
Tech Legend
Not familiar with that charger ...sorry...
if its a charger design for Li-Po, that is what you would see occur...
George W. Cherry
Old 03-07-2007, 11:20 AM   #833
[QUOTE]
thanks mr black
i thought as much but it's nice to have it confirmed
daffy is offline   Reply With Quote
Old 03-07-2007, 11:29 AM   #834
syndr0me's Avatar
Trader Rating: 32 (100%+)
The only difference is the sticker. Peak seems to rebrand Orion stuff with their sticker. In this case, the price on the Peak batteries is lower, but it's identical in every way but the sticker, which is red instead of blue and says Peak instead of Orion.
syndr0me is offline   Reply With Quote
Old 03-07-2007, 12:33 PM   #835
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking Orion Avionics Chargers
I have been using the ICE charger, and its been great for my LIPOS's. However, I need something that can charge 2 lipos at the same time. I have searched and found the MRC Super Brain 977 charger, which charges LIPOS and can charge 2 lipos at the same time. It sells for $95 at towerhobbies. However, I have seen in this forum some mention of some guys using the Orion Avionics Advantage charger, which is only $29. I could buy 2 of these and for $60 basically be able to charge 2 lipos at the same time also...the problem is that according the pictures on towerhobbies, it doesnt have wires and tamiya plugs or banana plugs at the ends to be able to charge the Orion packs...how are you guys doing this?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 03-07-2007, 12:40 PM   #836
I've been using Lipos for about three years. I found one I had forgot about at the bottom of a box of RC parts. Not sure when or how much I charged it but it has been at least two years. It still had 80% of its charge. It helps that it set in a cold basement. Heat is the major killer of Lipos...the hotter they are, when you cycle them, or when they are sitting around, the faster they will age (permanently lose capacity.)
You can peak them at any time, but it really isn't necessary. Just don't leave them in your hot car. If you really want to increase their life (though it is head and shoulders better than NiMh now) you can leave them in the refrigerator. Just be sure to get them back out, with enough time to fully warm up, before you use them. The cold temperature really knocks down their performance.
Disaster is offline   Reply With Quote
Old 03-07-2007, 12:40 PM   #837
Be careful the Brain. There was one version...not sure if it is the 977 that doesn't use voltage feedback...only capacity. If you set the wrong capacity, or if the battery is only partly drained (repeak situation) you will fry the battery and there will be fire. It is very dangerous to use on Lipos...even though it says it has that capability. I prefer a Lipo only charger. They are really inexpensive and I know there is no way I will make a mistake with the settings (accidently charge Lipo on the NiMh setting.)
Old 03-07-2007, 02:57 PM   #838
flying G.E.O.'s Avatar
I just purchased 3 of the 3200 packs. Question...... I am going to fully charge them today, but it could be 3 days, or it could be 3 weeks before I get to use them. At what point (how many days gone by) before I would want to repeak them before I run? In other words, 3 days don't bother, 2 weeks, might want to repeak, etc... ?????
thanks,
eric
i charge mine almost 5 days before and use it on the weekend with minimal repeak. We're talking 50mah self discharge only. I dont know why this thing doesn't self discharge much .
Anyone know what is the shelf life of lipo batts if not used for a long time? Do they degrade in performance after months in storage?
www.3dgallery.co.nr
flying G.E.O. is offline   Reply With Quote
Old 03-07-2007, 03:00 PM   #839
kuzo's Avatar
Send a message via MSN to kuzo
At least 2 of my packs came with an insert that specifically said do NOT use the MRC 977 charger. Don't known the reason, perhaps Mr Black has an idea.
kuzo is offline   Reply With Quote
Old 03-07-2007, 03:07 PM   #840
Yes, they degrade proportional to the temperature over time. You can greatly reduce the degradation by keeping them cooler. The degradation is not linear...it goes up considerably as the temperature increases over room temperature. As I mentioned in my earlier post, do not leave them in a hot car. A cool basement is a better place and if they sit for long periods the refrigerator is not a bad idea.
If you do a web search you can find charts and graph of the life vs. cycles and temperature.
They eventually fail, often from shorts in a cell. This is more likely to happen with heavy charges and discharges, impacts and poor production tolerances.
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
