Old 03-06-2007, 09:42 AM   #811
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Iceracer
Is Peak Performance as good as Team Orion's? Does it use Kokam cells?
no difference
What do they mean by "40% more run time than NIMH equivalents". Equivalent MAH rating, or weight? ????
mah rating
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-06-2007, 10:27 AM   #812
kuzo's Avatar
Send a message via MSN to kuzo
Originally Posted by Disaster
Thanks. I see they come with an external Tamiya power cable that plugs into the battery. Do they also come with an external balance cable for plugging into that port? What type of connector do they use? I'm used to Lipos with external cables and plugs.
You need to mod a connector using the standard size plugs plus these 2mm plugs following the attached image. This is for when using the Orion Avionics Balancer , I don't know about the others. I have a better image of one I wired up posted somewhere probably in this thread. Edit: I found and attached it.
On a side note regarding balancing - I have 8 Orion Platinums that have varying amounts of usage. Not one has needed to be balanced yet. When checking with a multimeter, each cell is within .02V of each other. Out of balance is considered .20V difference or more.
Team Orion 3200mAh Race Spec LiPo-harness_instr.jpg   Team Orion 3200mAh Race Spec LiPo-balancer.jpg
kuzo is offline   Reply With Quote
Old 03-06-2007, 10:44 AM   #813
Iceracer's Avatar
Originally Posted by Hebiki
no difference
mah rating
Their 3200's but they are really 40% more than tat. Makes me think of "This is Spinal Tap", and our amps go to 11.
Why don't they just call it a 4480 if its 40% more capacity than a 3200?
Iceracer is offline   Reply With Quote
Old 03-06-2007, 11:31 AM   #814
TMHippo's Avatar
Hi all
Who has run these 3200 Orion or Peak with a 19T? What was your run time like? Has any one done a endurance run and how long did the car run before slowing down?
I am asking because were I am racing there is not a Elec class yet and I must run with Nitro cars and their main is 15 min long.
Thanks Rodney
TMHippo is offline   Reply With Quote
Old 03-06-2007, 11:38 AM   #815
The 40% is an estimate based on how long the Lipo can deliver power at an acceptable voltage vs. how long the NiMh can. The Lipo has the advantage of more constant voltage through it's discharge curve but it is absolutely critical you don't go below it's threshold voltage. In an application where voltage wasn't so important (say flash for a camera) the difference wouldn't be so pronounced.
Disaster is offline   Reply With Quote
Old 03-06-2007, 11:42 AM   #816
Thanks. I copied the pics for future reference.
Old 03-06-2007, 12:48 PM   #817
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
after reading Lingers post's i`m reducated again
li-po for ever
giving up on 5 cell
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 03-06-2007, 12:58 PM   #818
Trader Rating: 38 (100%+)
Originally Posted by TMHippo
Hi all
Thanks Rodney
19 min with a novak 4300 brushless and Orion Platinum 4200. 15 min with a 3200/19T would be pushing it for 15min. You would probably have to gear way down and then still not have enough.
or8ital is offline   Reply With Quote
Old 03-06-2007, 04:53 PM   #819
Trader Rating: 198 (100%+)
I think you mean 4800 rookie!
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 03-06-2007, 05:01 PM   #820
Tsquare's Avatar
Hi all
Thanks Rodney
10 to 11 min's depending on track and driving style.
Tsquare is offline   Reply With Quote
Old 03-07-2007, 05:20 AM   #821
could anyone tell me if it would be safe to use orion's 3200 lipos during a wet race. ie.raining / standing water.
used mine sunday on a damp/greasey barham with no problems untill rain stoped play.
just wondering as the hard case does't appear to be waterproof and i'll rather be safe than sorry.
daffy is offline   Reply With Quote
Old 03-07-2007, 09:23 AM   #822
MrBlack's Avatar
The Battery can be made water proof by using a balloon or condom on the plug side with rubber bands sealing the where the wires are coming out.
Also you could apply a bead of shoe-goo or silicone to the side seam to also make it water proof.
Actually you could even use the pricived Tamiya plug ( you can even change the plug) and then use silicone or ShoeGoo around the edges and around the wires coming out of the ports to make it water tight.
Basically unless you do this water could pool in the case and water is very conductive.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 03-07-2007, 09:33 AM   #823
MrBlack's Avatar
We mean based on capacity. =)
Are test showed the 3200 LiPo's going roughly %40 longer then 3300 NiMH's
Old 03-07-2007, 09:34 AM   #824
I just purchased 3 of the 3200 packs. Question...... I am going to fully charge them today, but it could be 3 days, or it could be 3 weeks before I get to use them. At what point (how many days gone by) before I would want to repeak them before I run? In other words, 3 days don't bother, 2 weeks, might want to repeak, etc... ?????
thanks,
eric
speedythecat is offline   Reply With Quote
Old 03-07-2007, 09:38 AM   #825
MrBlack's Avatar
thanks,
eric
I run mine every Sat. and I cahrge them usually on Wednesday and then run on Sat. It takes more then a week before you see any noticable discharge and even then it is so minor that it's more like 2-3 weeks before you caould even tell out on the track.
We have batteries that have have a sat on a shelf for a year and have only lost 10-15% of their charge.
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
