Old 02-04-2007, 12:13 PM   #616
Rick Hohwart's Avatar
Originally Posted by SlamMan
Thanks for the input, Rick. This is my first "big" race so I appreciate the help. I do run NiMH packs when racing at the local Hobbytown club races so being able to easily switch back and forth would be nice. Would I realistically be able to add weight to the LiPo packs only, make weight and still have a relatively well balanced car? When running NiMH packs do you generally have to add weights to make weight? I run the Novak 13.5/GTB if that helps.
You should be able to add enough weight to the top of the battery and to one side. I prefer to fill the top, and run a lead strip along what will be the inside of the battery when installed in the car. Just make sure the battery is mounted so that the lead will not hit the drive belt. The pack offers enough flexibility in placement so that this will not be a problems.
The BL systems seem to be a bit heavier than brushed counterparts. I add 1 ounce to my proto TC5 when racing 19-turn. other cars like the Tamiya MSX might need more. You will likely have to add some weight.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 02-04-2007, 10:43 PM   #617
Tech Legend
Wild Cherry's Avatar
Hey Rick !
Any suggestions bout adding weight to a Ae B-4 with the 3200 ?
Someone I know suggested stopping by a Golf shop and check out their lead tape that they use...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 02-05-2007, 06:40 AM   #618
SlamMan's Avatar
Thanks a bunch, Rick. Much appreciated.
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 02-05-2007, 11:44 PM   #619
tom235's Avatar
i just ran the 3200 for the first time this weekend im sold i dont think there is more power but you have to like being able to charge them when ever you want and thats it.
i had to add about 3-31/2 oz of weight to make the buggy handle right because i was also running 4200 to see what the diff. in power would be and all that good stuff
tom235 is offline   Reply With Quote
Old 02-06-2007, 12:02 AM   #620
RCBuddha's Avatar
Trader Rating: 35 (100%+)
I had similar findings I actually got bored running my mabuchi-powered F103GT, and pulled off to find the motor blazing hot!
RCBuddha is offline   Reply With Quote
Old 02-06-2007, 09:37 AM   #621
minimanintaiwan's Avatar
Just got my pack! i'll be using it in a mini-M03 chassis and was wondering because the ends are exposed (hanging out both sides) can i protect the exposed area by using another layer of battery shrink wrap. This would involve encasing the entire pack in plastic shrink wrap and using a hot hair dryer blown on to it. Or is this pack as durable as it looks and no need for extra protection!?
Would doing this also have any heat/venting issues?
minimanintaiwan is offline   Reply With Quote
Old 02-06-2007, 09:55 AM   #622
Trader Rating: 198 (100%+)
With the near sub zero temps in parts of the US. Can this damage the 3200? For example the local shop is getting some of these in today. I do not think that UPS uses climate controled storage and delivery trucks that can deal with 32 below freezing. So the risk of freezing is real.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-06-2007, 12:04 PM   #623
shaggys40oz's Avatar
Default Lipo Low voltage cut-off modules??
Has anyone out there tried out the "NOvak smart-stop Li-Po Module"?
http://www.shopatron.com/product/pro....19780.0.0.0.0
It looks like a good thing to have to protect your 100$+ Lipo packs from being discharged beyond the point of no return. The 2 cell module has a cut-off at 6.25 volts.
I think I want one, is 6.25 volts a pretty conservative number?
I was looking at alow voltage detector sold by Maxamps.com and their alarm goes off when the battery hits 2.7 volts. I wonder if that is 2.7 per cell, 5.4 per 2 cell pack.
The difference between 6.25 and 5.4 seems possible, but 6.25 compared to 2.7 seems a litle funny.
Can someone enlighten me on this subject? Please forgive my ignorance
I have some RC cars and other stuff.....shaft drive forever!!
shaggys40oz is offline   Reply With Quote
Old 02-06-2007, 02:13 PM   #624
Novak's 6.25v is the spec for 2 cells (3.7v x 2 = 7.4) Most say not to run Lipos lower than 3.0v/cell or 6.0v for a car pack.
Novak's cutoff is on the safe side.
Maxamps has to be saying 2.7v/cell or 5.4/pack which I think is too low.
Sydewynder is offline   Reply With Quote
Old 02-06-2007, 02:35 PM   #625
Default Saddle packs
We poor XRay guys that run saddle packs will never be able to use lipos.I have not seen anyone address this issue.
My two cents
jackh is offline   Reply With Quote
Old 02-06-2007, 03:09 PM   #626
My two cents
How about these?
Saddle Packs
at Maxamps
Do they fit?
Old 02-06-2007, 03:20 PM   #627
UN4RACING's Avatar
Trader Rating: 22 (100%+)
jackh: Look up Xray and see if they can get you some of those stick pack plates they used to carry.
That would open the door to 4800's as well.
UN4RACING is offline   Reply With Quote
Old 02-06-2007, 03:29 PM   #628
Originally Posted by Sydewynder
How about these?
Saddle Packs
at Maxamps
Do they fit?
Hmmm, I have never seen these cell before. I will have to do more checking into them. Now if they can come up with a 4 cell lipo pack for my CRC 12th scale life would be great.
Jack
Old 02-06-2007, 03:48 PM   #629
Jack
Unfortunately 1 lipo cell is 3.7v and 2 is 7.4v. You're either going to always lose or be called a cheater.
Old 02-06-2007, 04:07 PM   #630
MrBlack's Avatar
This is a good device however remember it does not cut off all voltage just voltage from your motor, so still remember to disconnect your battery as your servos and receiver can still draw power and the on-off swith on many ESC's does not completely cut the circuit.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
