Old 01-16-2007, 08:59 AM   #571
Rick Hohwart's Avatar
Originally Posted by deadsethara
I still have my FMA AVC1 lipo cutoff which can be programmed. I'll install it and set it to 5.9v and see what happens.
I don't want to let the batteries go down to 5.7v even if it is just a spike. I want to make these babies last.
If it fails, its back to racing stock 27 (13.5 BL).
Thanks.
Keep in mind that 5.4V is the absolute lowest you can go. 5.9V will still be safe but you could go a bit lower if necessary.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 01-17-2007, 03:03 PM   #572
MrBlack's Avatar
Originally Posted by Drifter
but please answer me 2 questions:
-current in NiMh mode is adjustable from 0,1-10A. How big are the increments inbetween? 0,1A?
It charges NiMH from 1-5A in .1 Amp increment 1.2, 1.2, 1.3 etc.
-there are some new LiPos out there with 5000mAh. So the batteries will keep improving, will the 5A max. charge current in LiPo mode be enough in the future?
Yes as you will be able to charge thenm at 1C = 5A
To sum it all up: do you think the Advantage Flight Charger is a very good option for me, or should I consider the Orion Advantage Advanced charger as a better choice?
Thanks!
My personal favorite is the Flight charger I developed both and the Advanced is great with a lot of features but for me I like the simplicity of the Flight charger along with the small size.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 01-18-2007, 11:54 PM   #573
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
how much weights will you guys out to counter weight the electronic side? specialy using gtb and brushless motor? cause i was trying to set mine up(cyclone) and its a little bit hard. there is to much preload on the electronic side than the lipo side and im trying to keep as almost same preload on both shocks for consistancy.. i did put 28g on the front left side and 31g on the rear left of the chassis. but still far from balance.
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 01-19-2007, 09:17 AM   #574
ljohnson's Avatar
I haven't totally balanced it, but in my 415 msx with a 3200, KO2413 servo, KO302f rx , mamba max esc and a plettenburg shadow motor I'm looking at about 120g of lead on the battery side to balance the car. A full length motor will need a bit more. Fitting that much ballast on the car is taking some planning.
Even 120g is still lighter than running a nimh pack.
From a little testing my Evo IV will need about half the weight, around 60g, due to the motor being closer to center.
ljohnson is offline   Reply With Quote
Old 01-19-2007, 10:44 AM   #575
minimanintaiwan's Avatar
Default which charger?
Can somebody list a few good chargers for Orion's 3200 carbon lipo battery. I assumes Team Orions advantage charger is best suited but its a bit pricey. Any other alternatives? Sorry, if this has been covered, i did check a few pages
Anyone run a M03 mini with this lipo pack? how'd it fit and run?
minimanintaiwan is offline   Reply With Quote
Old 01-19-2007, 10:51 AM   #576
SlamMan's Avatar
The Orion Flight Charger mentioned 3 posts up.
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 01-19-2007, 11:06 AM   #577
GaryA's Avatar
Hi Mini
The Scorpion 2s charger is a great balancing Lipo charger. Be sure and get the charger adapter for the Orion pack. Check it out at fmadirect.com. Click on "Scorpion Products".
I have a Mini also and the Carbon 3200 fits perfect. Hope this helps.
GaryA is offline   Reply With Quote
Old 01-21-2007, 07:10 AM   #578
Default charger
Thanks guys, I'll check out the Flight charger and the Scorpion. I like the fact the Scorpion balances the cells too.
GaryA - How'd the mini run? Any issues with the reduced weight especially handling?
Old 01-21-2007, 12:12 PM   #579
ljohnson's Avatar
When I ran a 3200 pack in my m04m on carpet it didn't seem to need any major setup changes, a slight change in springs might have helped, but nothing major.
Atleast not on a silver can - Running a Mamba Max 4600 did need setup work. Tamiya 60D tires where not intended for that kind of power
Old 01-21-2007, 12:31 PM   #580
pinggoy's Avatar
on a cyclone runnin gtb with 13.5 and mini spektrum with 9550 servo i had to put almost 200g of weight in order fo it to balance in my hudy balancing tool.that sucks...
also i have an extra orion advantage lipo charger for 130$ nib if someone is interested.
TAMIYA TRF416X
Old 01-21-2007, 11:26 PM   #581
GaryA's Avatar
GaryA - How'd the mini run? Any issues with the reduced weight especially handling?[/QUOTE]
Not much difference in handling It's maybe a little more top heavy. You will just have to try it. You'll probably like it.
Old 01-22-2007, 03:44 PM   #582
shaggys40oz's Avatar
I may be intersted in buying in the next week or so. Is 130 shipped to Wa state?
-Matt
I have some RC cars and other stuff.....shaft drive forever!!
shaggys40oz is offline   Reply With Quote
Old 01-23-2007, 12:24 PM   #583
MrBlack's Avatar
I have seen some people re-route their servo lower in the car to counter act the top heviness when running LiPo. Once this is done it definately improves over all handling.
Old 01-23-2007, 05:52 PM   #584
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Which of the Novak Lipo cut-off switches would I need to use with the 3200 and/or 4800 packs? The 2 cell or 4 cell?
RCBuddha is offline   Reply With Quote
Old 01-23-2007, 07:08 PM   #585
kuzo's Avatar
Send a message via MSN to kuzo
You would need the 2 cell which would cutoff at 6.25V.
kuzo is offline   Reply With Quote
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
