Old 10-04-2006, 10:14 AM   #256
Regional Moderator
Darkseid's Avatar
Originally Posted by syndr0me
Anthony has a bunch of tire weights taped to his battery strap to make weight. It's really ugly! :-D He's got more tire weights on his FK05 than I've got on my real car.
I have no idea how many weights I'm going to end up needing with the new battery, but I'm sure it's going to require some creativity, and possibly a small business loan.
I used those ugly grey square weights you can get at any hobbystore. 8 (2oz) of them in all. Yuk! And anybody who knows how long I spend on wiring layouts, knows the look of my car is important to me, so those weights are absolutely KILLING me! But it had to be done, and for the close racing I've been hearing about in that class, I'm willing to suck it up.
TLR 22...Tamiya F104...
Old 10-04-2006, 10:15 AM   #257
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Mr. McGoo
i think those are the same - are you trying to use the new top deck - i can get my orion platinum to fit fine with the stock chassis, it is the 3.9 that won't fit - i just connect it at the rear of the car where the top deck actually is inbetween the connectors...
Yea, I'm using the new topdeck which seems to conveniently block all access to the holes. I really liked how it felt on the track though. Plus, if that's the design for the new car, and I decide to stay with Corally, seems like I'm going to need some kind of access to the connector under the deck. :-(
syndr0me is offline   Reply With Quote
Old 10-04-2006, 10:17 AM   #258
syndr0me's Avatar
I'm the same way, I like my stuff to look fast. I guess it's vanity.
Man, the SS4300/LiPo class is so damn fun. It really makes you want to reach out through the Internet and bitch smack these people who are trying to naysay brushless and LiPo.
Old 10-04-2006, 10:32 AM   #259
Regional Moderator
Darkseid's Avatar
Vanity. Well jezzz...you make people like us sound so bad when you say it that way.
People fear change...and fear a level playing field even more. So don't be mad at the naysayers. Just pitty them, and be waiting with open arms and a hearty "welcome to the class" when they finally make the switch.
Old 10-04-2006, 12:41 PM   #260
Hebiki's Avatar
Trader Rating: 26 (100%+)
Will these work? They're 90 degrees.
http://www2.towerhobbies.com/cgi-bin...&I=LXJPY2&P=ML
these are smaller.. but the good thing about this, you have something to grip. so when unplugging from the lipo. its easier to unplug.
the larger ones that are required for the lipo, even if you solder at a 90deg. angle. its not as strong and is harder to grab. if you solder it straight into the plug... ive had the wire come out even after soldering it and wrapping it in shrink wrap.
hopefully someone comes out with a connector thats the same as the one that syndrome has above, BUT fits the bigger connector.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-04-2006, 01:19 PM   #261
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
syndrome,
i belive they are the right diameter but are too short - i could be wrong, but i don't think i am....
as for the weights, i am about to do some solder weights like AWD did to his - just take your chassis and mold your own weights with solder and then tape the weights to the battery.
AWD's battery works great and helps with weight as well, but you will still need to add some more weight - on top of the battery strap is perfect
AWD=ME : )
Cool initials huh?
Andrew William Doherty
I know MCGoo said to jsut melt the solder in yur chassis, but I just wanted to clarify. Melt all the solder on a piece of wood to allow the rosin core to get out and be absorbed BEFORE you let it harden and then place the blob in the cell slot. Other wise you'll have a MESSY rosin mess all over your chassis. Amazingly the heat from the solder doesn't damage the CF AT ALL!
Old 10-04-2006, 03:29 PM   #262
MrBlack's Avatar
Hello Everyone,
The connectors listed above are 3.5 mm unfortunatley they are too small these are the same size as the one's we use on out new V2 endbell.
The connectors needed for the Platinum and the Carbon are 4mm and are called Orion Twisted Gold plugs #ori40003
You can also use the Avionics plugs http://www.teamorion-avionics.com/Ac...onnectorsPlugs they have a little lip that may help with what you are doing.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 10-04-2006, 03:40 PM   #263
MrBlack's Avatar
Also just a little tip on having to weigh chassis.
The industry as a whole knows the motor hanging off the side is not the best solution especially since Batteries get heavier and heavier and electronics get lighter and lighter.
Even the push by few for 4 cell is creating a concern amoungst chassis engineers and I think you may find a more centralized placement of things in the future.
Old 10-04-2006, 04:29 PM   #264
syndr0me's Avatar
Will the carbon batteries come with some male connectors for our ESC wires, or should I plan on purchasing those separately? I need 4MM, right?
How long, you think, until the hobby shops start sending these to customers? Another two weeks or so? I'm using some aging 3800s in our brushless class, and I've got noticeably less rip than the guys running LiPo. It's somewhat close on the straights, but they murder me out of the turns. I'm anxious to remedy that little issue. :-D
Old 10-04-2006, 04:31 PM   #265
syndr0me's Avatar
The JRX-S TypeR is really going to test this theory, especially if LiPo becomes legal, and weight limits are dropped.
Old 10-05-2006, 11:17 AM   #266
MrBlack's Avatar
Yes they will come with two male connectors wired to a Tamiya style connector. The reason we do this is by far the largst seeling battery conficguration is still the stick pack, also batteries either come with a tamya connector or now connector at all so those that use other connectors are obviuosely capable of resoldering.
We are scheduled to recieve them into our locations in the U.S.and Europe tomorrow. There was delay with the shipping company that delayed things by a couple of days. We will be sending them out next week and you should see them arriving in better hobbyshops within the next 10 working days.
Old 10-05-2006, 01:33 PM   #267
syndr0me's Avatar
Thanks for the information. Sounds like I've got another two or three race nights worth of lame old NiMH in my car. I hope you guys sell a million of these things, you deserve it. I don't know about the rest of the world, but locally, you're making people love racing again.
Old 10-05-2006, 02:34 PM   #268
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
WORD...............
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-05-2006, 02:44 PM   #269
Regional Moderator
Darkseid's Avatar
They certainly do!!!
Old 10-05-2006, 04:43 PM   #270
One suggestion I would like to see with these packs is maybe in the next gereration to add weight internally to match the weight of say a 3800mah Nimh pack. To really keep with the current TC's handling the same. I am going to lay weight into the recess anyway to match my 4200's weight and then put a sweet Carbon Fiber sticker over it that way until the current rules change I can pratice with these packs without changing my setup.
OK I am done, It was just a thought........
-Shookie <><
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
