Old 01-14-2008, 01:05 PM   #1741
Send a message via AIM to 4wd Racer
No, your answer is if you put in 3.2 Amps in the Orion/Peak 3200 packs (with 2 cells wired in a series), each cell would see 3.2 Amps charge. Now if you put in 6.4 Amps, each cell would see 6.4 Amps etc.
Ask yourself this, our today's standard 6-cell NiMh pack (with 6-cells wired in a series), if you charge it at 6.0 Amps, does each cell receive 1.0 Amps, or 6.0 Amps?
For the same reason with the above 3200 Lipo (2-cells in a series), you have your answer with the 6-cell NiMh. Which is each cell in the NiMh wired in a series would see 6.0 Amp charge, if the whole 6-cell NiMh pack was charged at 6.0 amps etc. Not 1.0 Amps each, etc.
4wd Racer is offline   Reply With Quote
Old 01-14-2008, 01:18 PM   #1742
SWTour's Avatar
4wd,
Thank you...and of course you are right.
I got backward in my brain...these are 2s1p (Not 2p1s) DOH! otherwise they would still only be 3.7 volts. (I need more MONDAY MORNING COFFEE)
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is online now   Reply With Quote
Old 01-14-2008, 01:29 PM   #1743
Actually it was I that made the first mistake, I didn't catch your post of 2p1s for the Orion/Peak 3200, so in that case, it looks like I need a cup of morning coffee as well!, pass the coffee, lol.
Old 01-14-2008, 08:11 PM   #1744
wallyedmonds's Avatar
Originally Posted by bin View Post
Hi guys, this may be a dumb question.
Ok here goes.
What is the difference between the Team Orion 3200 / 4800 lipos and the Peak Racing 3200 / 4800 lipos? Cos they seem like the same thing to me!
orion and peak 3200 and 4800 are the same.
but now orion have 3600 at 25c witch is cool.
wallyedmonds is offline   Reply With Quote
Old 01-14-2008, 09:29 PM   #1745
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Can anyone post a pic of there X-Ray T2 with this battery installed in it and with the proper weights installed to balance it out...
I would like to see where everybody is putting there weights...
HRCRACER123 is offline   Reply With Quote
Old 01-14-2008, 09:32 PM   #1746
JimmyMac's Avatar
T2 what? 007? If so, I have a pic of mine when I had a 007 last year with brushless 13.5 and GTB.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-14-2008, 09:37 PM   #1747
I have a the '007 so that would be cool or even a regular T2 would be nice as well.
Post some pics fellas..
Lets see those fancy rides..
Old 01-14-2008, 09:54 PM   #1748
JimmyMac's Avatar
Okay, well lemme drop them on photobucket and I'll post them here in a few minutes.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 01-14-2008, 10:09 PM   #1749
JimmyMac's Avatar
Okay, here they are. The last picture shows how much material you have to remove on the right rear center pulley bulk head if you want it to clear the 3200 pack. Plus if you want to use the battery strap, you need to shim it up to clear the weights added in. Also, you need to dremel down the battery guides if you want them to fit/secure the battery under the battery strap. Hope this helps...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 01-14-2008, 10:11 PM   #1750
JimmyMac's Avatar
Oh, and those are not XRay springs on the car. Some thought I had them backwards.. Fooled them..
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 01-14-2008, 10:21 PM   #1751
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
here's a 4800 mounted on a T2'007... weights are mounted directly on the pack. did pretty much the same with my 3600...
Team Orion 3200mAh Race Spec LiPo-dsc01562.jpg   Team Orion 3200mAh Race Spec LiPo-dsc01563.jpg   Team Orion 3200mAh Race Spec LiPo-dsc01561.jpg
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-14-2008, 10:23 PM   #1752
Wow you had to add alot of weight. It looks good though. Thats what I want a nice clean look..
Thanks for posting those pics.
Old 01-15-2008, 12:48 PM   #1753
Once I run the pack, lets say for practice and I run it for a good 8 minutes.
When I get back to my pit area can I just put it back on the charger or do I need to wait a little bit?
Old 01-15-2008, 04:12 PM   #1754
SWTour's Avatar
I come off the track - and start the re-charge before I go to corner marshal.
They normally take about 1800 - 2200 mah if I'm running one of the slower classes, and closer to 2800-2900 if I'm running a faster class. (We only run 5 minutes though)
Between my son and I, I always have ONE extra battery 'pre-charged' just in case I forget to recharge the one I just ran, but when ever possible...I never remove the pack from the car. (GOTTA LOVE IT)
Joe Myers
Old 01-16-2008, 01:26 AM   #1755
JimmyMac's Avatar
You can get away with only 1 pack on a race day if the races are 5 minutes and you have 1 hour between each round. I have done this before. But I usually take 2 packs with me. For me running a 13.5 at our track for a 5 minute race...... it would take about 45 minutes to repeak the pack at a 3.2amp charge rate. And as SWTour stated, you can toss the pack on the charger right as soon as you are done racing it. Just don't forget to never discharge the pack down to where the car is crawling to a halt. So when you notice it to start to slow down on the track, pull it off immediately and charge it back up.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
