Old 10-03-2007, 07:44 AM   #1681
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Originally Posted by BullFrog View Post
My battery came back today.Only I have no way of testing it in the car- no esc- or motor yet. Are these new 3600 the same size as the 3200?
Hey Bulfrog - was it the pack or was it something else? I ask b/c I smoked ESC #2 yesterday after changing EVERYTHING else on the car. Mine is going back to day so hopefully I will know soon.
Just to settle my curiosity - what was your exact setup?
rcarmchl is offline   Reply With Quote
Old 10-03-2007, 12:26 PM   #1682
Trader Rating: 26 (96%+)
What charger should I use to charge the 4800s up at a 2c rating? Does it take a special program or can I just pick up an astroflight 109 and set it at 9.6 amps?
party_wagon is offline   Reply With Quote
Old 10-03-2007, 01:53 PM   #1683
rcarmchl's Avatar
If I am not mistaken you have to file or sand most chasis' to fit a NIMH pack anyway.
Old 10-03-2007, 04:38 PM   #1684
linger's Avatar
Originally Posted by syndr0me View Post
I'm guessing Linger's question came about because Kokam doesn't appear to have a 3600mAh cell.
It's quite possible that Kokam released a 3600 cell. It would not take too much new tooling. The electrode size is the same, they would only need to produce a thicker cell. Since the 3200 cell is just 7.6mm thick - they can easily add more layers/stacks for additional capacity. They only need a new punch and die for the alumimum pouch, which is relatively cheap.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 10-03-2007, 04:47 PM   #1685
linger's Avatar
Originally Posted by Fastforward View Post
I must be missing something. My 3200's have plenty of capacity for stock club racing. 20C vs 25C, what is the big deal? Would somebody please explain.
Since the motor current is pretty much fixed - a 3600 25C battery will hold higher voltage under any load compared to a 3200 20C battery since the 3600 is less stressed. Even if you don't need the extra capacity - you will get more voltage.
We are assuming the same manufacturer - since the C rating is mostly a marketing term and a 20C from one manufacturer is not equal to 20C from another manufacturer.
Old 10-03-2007, 04:49 PM   #1686
I can't answer that yet.I have not seen my ESC (2) or motor.I would probably guess it was the ESC that shorted the motor and battery.But then I've run both my orginal ESC (Novak) and 13.5 (Novak) motor for over one year without any problem with both 3800 and 4200 batteries.I never esperienced this problem until I tried the lipos. Now will this stop me from using lipos- No. I don't plan on running cells again- just lipos.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 10-03-2007, 05:08 PM   #1687
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
You can most likely fix the battery. If they short, they blow/unsolder the tabs on one side of the board. You can pull them out a little and reattach them just like a motor wire. BTDT a couple times.
Turbo Joe is offline   Reply With Quote
Old 10-07-2007, 11:10 AM   #1688
I am looking to pick up a pair of the Orion\Peak lipo packs and had a couple questions about them.
I will be using an Orbit Microlader for charging duties and it has cell ballancing options for several of the major type of connections. Does anyone know what kind of ballancing port these Orion\Peak lipos utilize?
Fasttrak
Fasttrak is offline   Reply With Quote
Old 10-07-2007, 11:27 AM   #1689
Big Daddy Cool's Avatar
Send a message via ICQ to Big Daddy Cool
Fastrak: That would depend on your balancer. I built my own balancing harness for my orion platinum / imax b5 setup. The imax requires esky style balancing leads. I just soldered the pos/neg (red/black) lines to the main output plugs. Middle balancing lead blue wire goes to the balancing port with a smaller plug. See pic attached. I hope this helps.
Big Daddy Cool is offline   Reply With Quote
Old 10-07-2007, 12:07 PM   #1690
Thanks for that, just having a difficult time deciding what it is I actually need from Orbits website. May have to call Germany and find out.
Fasttrak
Old 10-11-2007, 03:24 AM   #1691
Hi guys, maybe some of you can help me out. My 3200 is about 6mnths old. Im having problems about 3/4 through the pack. It would start to stutter/cog then just cut-off. Ive been told the voltage could be dipping below cut-off. Now ive tried balancing the pack, both cells were fine. Then i fitted a cap to the rx cause when i would throttle it & use the servo at the same time, you could hear it have trouble, meaning it could not power both servo nor motor at once. This is all still near cut-off. I do not know what else to do. Does anybody have a suggestion as to what else i can do, or is my pack a dud
This happens about 5-10mins before cut-off. Im using a mamba max esc with a vortex 7.5 motor (& its not the motor causing the cogging). Spektrum DX2.0 with Novak Glitch Buster cap, TT01 with 8.35FDR...
Drift Demon is offline   Reply With Quote
Old 10-19-2007, 10:29 PM   #1692
ottoman's Avatar
R/C Tech Charter Subscriber
OK... I just read the following post on "Hobby Talk"...
"The Orion pack is a 2S – 1P pack but it means that to get the voltage up to 7.4 there are two cells in series but there is also one cell in parallel to get the pack capacity up. The reason it is still called a two cell pack is because that is the way the charger “sees” it. The two cells in series are “seen” as only one cell."
Is this correct? I always thought the the Orion pack was 2 cells in series
ottoman is offline   Reply With Quote
Old 10-20-2007, 03:31 AM   #1693
SWTour's Avatar
ottoman,
according to ORION the 3200 pack IS two 3.7 volt cells in series. Those two cells in series constitute one parallel cell from what I understand. (Still just two cells in the case)
Whereas the 4800 pack is 4 cells in total, (2 series + 2 series)=2 parallel.
Both are recognized by the charger as a 2 cell pack (Not a 3 cell pack as McLin indicated on HobbyTalk)
I have not torn a 3200 pack apart, but I believe each cell in the 3200 pack IS a 3200 mah cell, but in the 4800 pack, I believe each cell is only a 2400 mah cell, but when parallel wired the two packs together make up 4800 mah's.
(It would be like taking 2 of your 6 cell 4200 IB packs and wiring them together in parallel, I believe you would actually have 8400 mah's )
SWTour is offline   Reply With Quote
Old 10-20-2007, 05:43 AM   #1694
magm20001's Avatar
so that means the 4800 packs cant be balanced individually? they can only be balanced 2-2
RIP Kanye West ..... Mom
magm20001 is offline   Reply With Quote
Old 10-20-2007, 06:33 AM   #1695
kuzo's Avatar
Send a message via MSN to kuzo
As far as I know you never balance cells in individually parallel no matter the configuration. Every balancer I've ever seen has taps for 2S, 3S, etc with no regard for how many in parallel.
Someone smarter than me will have to correct me, but I'm guessing that cells in parallel balance with each other on their own.
kuzo is offline   Reply With Quote
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
