Old 08-17-2007, 05:50 AM   #1591
SkeeryJones's Avatar
Originally Posted by peded View Post
I also have a few questions about lipo before I consider switching.
I presume the Duratrax Ice is capable of charging such batteries. What charge rate would you reccommend for charging?
I normally run down at a Hobbytown Race and we have 2 qualifiers and 1 main. The qualifers are 4 minutes each and the main is 5 mins. So in total its 17 minutes of racing plus practice so about 25-30 mins total.
Would this Orion 3200 be able to run on a single charge or would you reccommend charging in between runs?
dude its only a 3200mah pack, i tested it only has about 2200mah of usable energy b4 it reaches 6v, so you can only run it maybe 6.5minutes. so u can do the math.
good thing is you dont need to wait for the pack to cool b4 u re-charge.
SkeeryJones is offline   Reply With Quote
Old 08-17-2007, 08:59 AM   #1592
I ran my Orion 3200 for the first time Wednesday night. I run a B4 in the stock class. The battery worked great. I charged it earlier in the day and arived at the track with the battery allready installed and ready to go ( mI got their 5 min before the race started). After the 5 min heat race I recharged the battery (took about 20-25 min), ran another 5 min heat race (recharge 20-25 min), and then the main. I had zero problems.
P.S. I am using the Scorpion balance charger.
azgreg is offline   Reply With Quote
Old 08-17-2007, 10:46 PM   #1593
rcgen's Avatar
Originally Posted by BullFrog View Post
This Question has probably been asked but : I just got an Ice Charger and a 3200 Peak lipo. I wanted to get a balancer but the hobbyshop said the pack did not need one. However I did notice last night that here is a small hole that says equalizing. So what type of balancer do I need to get and will it go inline .Or what will I have to do to make one go in line (if possible?) I previously had a 4800 that would not fit in my TC.So it's been several weeks trying to get all this stuff together and fitting into the car (RDX PHI).The 3200 are still a tight fit but it will work. Another question is it safe to plug the ESC directly into the battery.I plan on making a pig tail to keep the esc wired and a plug to charge the battery. I'll never have to remove either plug.I've ordered the Corally plugs that fit the batteries.
You don't really need a balancer. When each cell gets out of balance, you will need to charge each cell individually. The 3200 has that center connector. I think its a 2mm. Connect the charger's positive connector to the battery's positive and the charger's negative to that center connector and charge accordingly. After that 1st cell is finish, connect the charger's positive to the center 2mm connector and the charger's negative to the battery's negative and charge away.
I've ran mine for 3 weeks for 3 races so that's about 9 cycles. I checked the voltage on each and each voltage is even...
rcgen is offline   Reply With Quote
Old 08-18-2007, 10:30 AM   #1594
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by VooDooPH View Post
anybody tried using the trakpower balancer on the orion packs?
to answer my own question... the Trackpower balancer works on the Orion/Peak. Tried it and love it.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-18-2007, 08:18 PM   #1595
hey guys just for any one on the fence bout lipo's
i bought 2 lipo's thinking if i need a min of nimh packs for a nights racing then ill need to lipo's WRONG.
i used a nimh for a practice run came in chaged packs ran my lipo 1st run came in back on charge no waiting. waited half hour next run or 1st qualifier same thing back on charge not waiting. did this for 3 qualifiers and for the final i had 30 mins max to charge my battery and at 1c i wasnt confident to run it especially seen as its an 8 min final.
u can get a nights racing about 6 runs total in 5 hours so not bad. im gonna bump up to about 4.5 amps just so i can make it easier a mate charges at 5 and so far so good im going to get a balancer just because i want my packs to last.
so thans orion/peak for such sweet products. my nimnh are now practice packs lol
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 08-22-2007, 06:45 PM   #1596
Trader Rating: 25 (100%+)
Just got my first Orion 3200 and Duratrax Ice Charger today.
I havent hooked anything up yet so...
Rookie?? Is the battery already charged out of the box or does it need charged?
buckeye-mac is offline   Reply With Quote
Old 08-22-2007, 06:51 PM   #1597
You should charge it first. It won't hurt a thing to do so.
gezer2u is offline   Reply With Quote
Old 08-22-2007, 06:51 PM   #1598
kuzo's Avatar
Send a message via MSN to kuzo
It needs a charge. They ship with around 50% I think.
kuzo is offline   Reply With Quote
Old 08-22-2007, 07:07 PM   #1599
i hooked up to the ice and the output voltage read 7.639 volts.
I take it its reading the output of the battery, seems to me thats fully charged.
Am I reading that correctly.
Old 08-22-2007, 07:13 PM   #1600
kuzo's Avatar
Nope, fully charged with these batteries is at 8.4V. The 7.4 number is its nominal voltage just like NiMH packs are listed at 7.2V but they charge to over 9V.
Old 08-28-2007, 12:21 PM   #1601
MrBlack's Avatar
The battery comes with around an 80% charge and it is recommended to charge it fully (8.4 volts) before use.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 08-28-2007, 12:27 PM   #1602
Trader Rating: 38 (100%+)
MrBlack, any update on new lipo products from Orion?
or8ital is offline   Reply With Quote
Old 08-28-2007, 01:40 PM   #1603
MrBlack's Avatar
I am hoping to have an announcement out within the next week or two.
Old 08-29-2007, 03:23 AM   #1604
SWTour's Avatar
Charging the 3200 @ 2c
I know I read someplace a while back that ORION supports these batteries being charged at 2c (6.4 amps)
Is this info on the ORION Web Site anywhere?
SWTour is offline   Reply With Quote
Old 08-29-2007, 05:08 AM   #1605
MrBlack - is shoppeakracing.com still functional? they have the cheapest lipos in town...
Drift Demon is offline   Reply With Quote
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
